Arduino DUE, ENC28J60 and UIPEthernet
Hi people
I've connected ENC28J60 to Arduino Due and I'm using UIPEthernet V1.59
It works fine in first 5 minutes after that it frozes
I've included all header files
#include <SPI.h>
#include <Dhcp.h>
#include <Dns.h>
#include <ethernet_comp.h>
#include <UIPClient.h>
#include <UIPEthernet.h>
#include <UIPServer.h>
#include <UIPUdp.h>
Please help me I'm working on this already one week
(deleted)
Hi all,
I have the same problem with Arduino DUE, ENC28J60 and the UIPEthernet V1.59 librairy.
It works fine 5 minutes and freeze.
Here's the entire test code :
#include <SPI.h>
// The connection_data struct needs to be defined in an external file.
EthernetServer server = EthernetServer(80);
  uint8_t mac[6] = {0x00,0x01,0x02,0x03,0x04,0x05};
  IPAddress myIP(10,6,18,200);
  Serial.println("@ : 10.6.18.200 ...");
  Ethernet.begin(mac,myIP);
  server.begin();
   if (client) {
     Serial.println(F("new client"));
     // an http request ends with a blank line
     boolean currentLineIsBlank = true;
     while (client.connected()) {
       if (client.available()) {
         char c = client.read();
         // Serial.write(c);
         // if you've gotten to the end of the line (received a newline
         // character) and the line is blank, the http request has ended,
         // so you can send a reply
         if (c == '\n' && currentLineIsBlank) {
           // send a standard http response header
           client.println(F("HTTP/1.1 200 OK"));
           client.println(F("Content-Type: text/html"));
           client.println(F("Connection: close"));  // the connection will be closed after completion of the response
           client.println(F("Refresh: 5"));  // refresh the page automatically every 5 sec
           client.println();
           client.println(F("<!DOCTYPE HTML>"));
           client.println(F("<html>"));
           // output the value of each analog input pin
           for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
             int sensorReading = analogRead(analogChannel);
             client.print(F("analog input "));
             client.print(analogChannel);
             client.print(F(" is "));
             client.print(sensorReading);
             client.println(F("
           client.println(F("</html>"));
         if (c == '\n') {
           // you're starting a new line
         } else if (c != '\r') {
           // you've gotten a character on the current line
           currentLineIsBlank = false;
     // give the web browser time to receive the data
     delay(1);
     // close the connection:
     client.stop();
     Serial.println(F("client disconnected"));
I've change all the 'println' with 'println(F(' to try to save the SRAM but no result.
It's very strange !
