Arduino Due Ethernet Shield and DueVGA Library
Hello all Arduino Forum!
I'm using the Arduino Due with the Wiznet W5100 Ethernet Shield and it uses the all of the Arduino Due's SPI header, and I'm using the @stimmer's DueVGA library and its 640x480 and 800x600 modes uses the SPI header's MOSI pin, so i can't reach to MOSI pin, because Wiznet W5100 Ethernet Shield uses and closes it. Is there a way for using MOSI pin from the Due's pins, e.g 51, 11 or another pin?
Thanks for helping :)
AFAIK, the 6 pin SPI header (called ICSP on other Arduinos) is the only way to get to the SPI data lines on the Due.
A long while ago, I suggested that the ICSP socket pins be extended on the ethernet shield to allow access to the SPI data lines on the top of the shield, but my suggestion was ignored. :frowning:
lol it could be very cool :( I will try solder a header to Ethernet Shield's ICSP header, i hope it work :/
