I'm using flash memory to store data in arduino due.
Could You tell me what addreses do I have available ?
My sketch is using
DATA: [== ] 20.6% (used 6744 bytes from 32768 bytes)
PROGRAM: [== ] 24.2% (used 127108 bytes from 524288 bytes)
I'm using GitHub - sebnil/DueFlashStorage: DueFlashStorage saves non-volatile data for Arduino Due. The library is made to be similar to the EEPROM library. library to store data.
I want to use addresses from 0 to 650 000 - but at this point I'm not able to write all of them,
sometime arduino hangs when I try to write to some address., sometimes not write data under address I want.
How can I detect which addresses can I use to write ?
thanks in advance
