Arduino Due + HC-05
Hi, I am new with Arduino, I have project that requires connect bluetooth as (Master) to my Due,my problem is I am not able to get AT Command work from serial monitor, I tried all possible solution(band rate etc..) google for solution but reach nothing, if anyone can help I be so grateful to. and thank you in advance
Im not going to try and guess what you are doing wrong, please provide more detail, such as what you have tried, your errors, your code (and for the love of God please use code tags, please), how you connected the device to your due, pictures would also be nice if they were relevant.
Thank you for replay,what I am doing is an easy thing, it is detect my mobile to open my car doors and lock them when it disconnect from mobile, I have a problem with forgetting doors open all time ;), as I mentioned it is the first sketch I ever made, my programming background is C#, let us say I need sketch(tutorial) from zero point,
amer65:
You might find the following background notes useful
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
