Arduino DUE - How to change PWM Frequency
Hello,
i have two water valves which i like to control with my Arduino Due via PWM. The frequency which is required for the valve is 180Hz to 280Hz and i would like to use pin 9 and 10 on the board. How can i switch the Frequency to 200Hz? Can someone give me an example code?
Thanks
Not sure, but I am affraid, that the Arduino DUE needs then a bit more detailed treatment:
Not directly fitting, but it opens the perspective to fiddle directly with the timers close to the hardware.
If you not need the output with a high resolution, I would take into acount, to programme directly in the loop() with micros() timings.
Without waranty (it´s not tested and needs adjustment to your needs):
int dutyCycle01 = 0; // 0-100 %
unsigned long currentTime = 0;
unsigned long lastRisingEdgeTime = 0;
bool output = false;
  currentTime = micros();
  if ((currentTime > (lastRisingEdgeTime+4999)) && (output == false)) //if one 200Hz cycle is over (1000000 us div 200 --> 5000 us per cycle) ...
      output = true;
      lastRisingEdgeTime = currentTime;
  if ((currentTime > (lastRisingEdgeTime+(dutyCycle01*50))) && (output == true)) //if duty cycle is reached ...
    output = false;
  if (output)
     //set output pin accordingly
