I'm trying to read a temp/humidity sensor and display the values on an LCD.
here is the code snippet:
// x and y coordinates for text positions
// x is vertical coord. 0 is at bottom, 480 at top (landscape mode)
// y is horizontal coord. 0 is at left 800 at right
int tx=470, ty=80; // time text
int tdx=320, tdy=30; // date text
int tmpx=240, tmpy=10; // temperature text
int tmpsx=100, tmpsy=10; // set temperature text
int Xsize=82; // font width
float ts=71.0; // user set temp
// Reading temperature and humidity
delay(370); // delay to prevent polling sensor too fast
int chk = DHT.obtain22(DHT_PIN);
float h = DHT.humidity;
float t = DHT.temperature;
float tf = (t*1.8)+32; // convert celsius to farenheit
tf=((int)(tf * 10 ))/ 10.0;
Serial.print("temp = ");
Serial.println(tf);
Serial.print("hum = ");
Serial.println(h);
Serial.print("chk = ");
Serial.println(chk);
Serial.println("ok here 1.");
if (tf != tf_old)
Serial.println("ok here 2.");
char tempF[12]; // character array to hold value. # of digits plus 1
Serial.println("ok here 3.");
//String strtemp; // create string strtemp
Serial.println("ok here 4.");
dtostrf(tf,5,2,tempF);//+"°F"; // convert float to a string
Serial.println("ok here 5.");
// strtemp.toCharArray(tempF,8); // pass value of string to char array output is tempF
Serial.println("ok here 6.");
// temp display
myGLCD.setFont(LiberationMono96);
myGLCD.setColor(255, 255, 255);
myGLCD.setBackColor(0, 0, bckb);
myGLCD.print(tempF, tmpx, tmpy, 90);
tf_old=tf;
Serial.println("ok here 7.");
if (h != h_old)
char humidity[12];
//String strhumidity;
dtostrf(h,5,2,humidity);//+"%RH";
// strhumidity.toCharArray(humidity,5);
// humidity display
myGLCD.print(humidity, tmpx, tmpy+400, 90);
h_old=h;
here is the output:
temp = 77.30
hum = 32.60
chk = 0
ok here 1.
ok here 2.
ok here 3.
ok here 4.
Then it just hangs there, totally freezes.
What did I do wrong? I am using Arduino IDE 1.5.8 beta on an Arduino Due.
Well I figured out what it was. The Due ran out of RAM.
I removed one of the large fonts I was using and it runs now.
Thing is I am running a 7" TFT LCD and need the big fonts. I am making a clock/thermostat and would like to see it from across the room.
So now I have 2 thoughts:
Is to upgrade to an Intel Galileo which I believe has 256MB of RAM. Much more than the 96kb of the Due.
or
Find out if I am accessing all 96kb. The specs for the Due say it has 64kb of RAM + 32kb of RAM. Not sure what that means. Am I accessing all 96kb or just 64kb by default? How do I access all 96? Maybe just 32kB more would be enough?
or
Optimize my code somehow to still work on the Due without sacrificing font size.
or
Add RAM to the Due. Is that even possible? Will run just as fast? Can it be done over I²C or SPI?
Yes you can use an SD card too. In your case, you shouldn't have to worry about wear out, why do you think this is a problem? You just write the fonts only once in that memory, then all you will do is reading from it. Wear out problems only happen after many write/erase cycles on a same memory cell.
This will just add a whole new box of cans of worms...
You have 96KB of contiguous RAM space, though there is a slight chance that you can't have an object/structure/array larger as 64KB...
Well, impossible to say without seeing you code. But then I have seen sketches like what you describe running on a Mega2560, which has only 8KB of RAM...
Maybe, but I doubt that this will be an easy route...
