arduino due + LCD screen adafruit does not display the program Hello world
Hello everybody, I'm using an arduino due and a LCD screen adafruit. The lcd screen is the rgb lcd shield kit w/ 16*2 character display.
I implemented the following program which is in
The code is
Example code for the Adafruit RGB Character LCD Shield and Library
This code displays text on the shield, and also reads the buttons on the keypad.
When a button is pressed, the backlight changes color.
// include the library code:
#include <Wire.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
// The shield uses the I2C SCL and SDA pins. On classic Arduinos
// this is Analog 4 and 5 so you can't use those for analogRead() anymore
// However, you can connect other I2C sensors to the I2C bus and share
// the I2C bus.
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// These #defines make it easy to set the backlight color
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
  // Debugging output
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD. We track how long it takes since
  // this library has been optimized a bit and we're proud of it :)
  int time = millis();
  lcd.print("Hello, world!");
  time = millis() - time;
  Serial.print("Took "); Serial.print(time); Serial.println(" ms");
  lcd.setBacklight(WHITE);
uint8_t i=0;
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
  uint8_t buttons = lcd.readButtons();
  if (buttons) {
    lcd.clear();
    lcd.setCursor(0,0);
    if (buttons & BUTTON_UP) {
      lcd.print("UP ");
      lcd.setBacklight(RED);
    if (buttons & BUTTON_DOWN) {
      lcd.print("DOWN ");
      lcd.setBacklight(YELLOW);
    if (buttons & BUTTON_LEFT) {
      lcd.print("LEFT ");
      lcd.setBacklight(GREEN);
    if (buttons & BUTTON_RIGHT) {
      lcd.print("RIGHT ");
      lcd.setBacklight(TEAL);
    if (buttons & BUTTON_SELECT) {
      lcd.print("SELECT ");
      lcd.setBacklight(VIOLET);
I power the LCD with 5V. The 5V provided by the Due. The third pin of the lcd is linked to the 5V.
The 5 pin of the lcd is linked to the GND. The 11 pin of the lcd is linked to SDA. The 12 pin of the lcd is linked to SCL.
When I connect the LCD to SCL1 and SDA1, the program Hello_world.ino is displayed.
But when I connect the LCD to SDA 20 and SCL 21, the program Hello_world is not displayed and black bars are displayed because the LCD is correctly powered.
My question is the following, how use the SDA 20 and SCL 21 pin to display the program Hello_world ?
Thanks for the answer.
