Arduino Due libraries (official and 3rd party)
Hi again @obihavemojo,
If what you want is to measure the frequency and due time (pulse width) of a digital signal, use tc_lib's capture objects. Have a loop to example capture_test.ino which comes with the library. I think you can adapt it easily for your purposes.
I hope it helps.
antodom: Hi again @obihavemojo,
I hope it helps.
Hi, thanks again, I want to do the measurements on a sine signals. Maybe converting sine to pulse is an option. In general, for higher frequencies of timer there is some jitter. The strange thing is sometimes for a higher frequency there is lower jitter than a lower frequency. It is like in somehow the timer frequency needs to be a multiple of certain values to reach the best behavior (lowest jitter). Not sure to be honest
EthernetWebServer
EthernetWebServer
To install using Library Manager
EthernetWebServer
From v1.0.3+, the library supports more Arduino boards ( SAM DUE, SAMD: ZERO, MKR, NANO_33_IOT, M0, M0 Pro, AdaFruit CIRCUITPLAYGROUND_EXPRESS, etc.)
From v1.0.2+, the library supports many more Arduino boards (Atmel AVR-s, Atmel SAM3X8E ARM Cortex-M3, STM32F series, ESP8266, Intel ARC32(Genuino101), Nordic nRF51(RFduino), Teensy boards, Realtek Ameba(RTL8195A,RTL8710))
Support Wiznet W5x00 or ENC28J60 Ethernet shields by using UIPEthernet library besides standard Ethernet library
This is simple yet complete WebServer library for AVR, Teensy,SAM, SAMD, ESP, STM32F, Intel, etc. boards running Ethernet shields. The functions are similar and compatible to ESP8266/ESP32 WebServer libraries to make life much easier to port sketches from ESP8266/ESP32.
The library supports
  1. HTTP Server and Client
  2. HTTP GET and POST requests, provides argument parsing, handles one client at a time.
Library is based on and modified from Ivan Grokhotkov’s ESP8266WebServer)
The EthernetWebServer class found in EthernetWebServer.h header, is a simple web server that knows how to handle HTTP requests such as GET and POST and can only support one simultaneous client.
Sample Code
#if    ( defined(ARDUINO_SAM_DUE) || defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_SAMD_MKRWIFI1010) \
      || defined(ARDUINO_SAMD_NANO_33_IOT) || defined(ARDUINO_SAMD_MKRFox1200) || defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) \
      || defined(ARDUINO_SAMD_MKRGSM1400) || defined(ARDUINO_SAMD_MKRNB1500) || defined(ARDUINO_SAMD_MKRVIDOR4000) || defined(__SAMD21G18A__) \
      || defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS) || defined(__SAM3X8E__) || defined(__CPU_ARC__) )
  #if defined(ESP8266_AT_USE_SAMD)
    #undef ESP8266_AT_USE_SAMD
  #endif
  #define ESP8266_AT_USE_SAMD      true
#endif
// For SAMD
  #define EspSerial Serial1
  #if defined(ARDUINO_SAMD_ZERO)
    #define BOARD_TYPE      "SAMD Zero"
  #elif defined(ARDUINO_SAMD_MKR1000)
    #define BOARD_TYPE      "SAMD MKR1000"
  #elif defined(ARDUINO_SAMD_MKRWIFI1010)
    #define BOARD_TYPE      "SAMD MKRWIFI1010"
  #elif defined(ARDUINO_SAMD_NANO_33_IOT)
    #define BOARD_TYPE      "SAMD NANO_33_IOT"
  #elif defined(ARDUINO_SAMD_MKRFox1200)
    #define BOARD_TYPE      "SAMD MKRFox1200"
  #elif ( defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) )
    #define BOARD_TYPE      "SAMD MKRWAN13X0"
  #elif defined(ARDUINO_SAMD_MKRGSM1400)
    #define BOARD_TYPE      "SAMD MKRGSM1400"
  #elif defined(ARDUINO_SAMD_MKRNB1500)
    #define BOARD_TYPE      "SAMD MKRNB1500"
  #elif defined(ARDUINO_SAMD_MKRVIDOR4000)
    #define BOARD_TYPE      "SAMD MKRVIDOR4000"
  #elif defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS)
    #define BOARD_TYPE      "SAMD ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS"
  #elif ( defined(ARDUINO_SAM_DUE) || (__SAM3X8E__) )
    #define BOARD_TYPE      "SAM DUE"
  #elif ( defined(__SAMD21G18A__) || (__CPU_ARC__) )
    #define BOARD_TYPE      "SAMD Board"
  #else
    #define BOARD_TYPE      "SAMD Unknown"
  #endif
#elif ( defined(CORE_TEENSY) )
  // For Teensy 4.0
  #if defined(__IMXRT1062__)
  #define BOARD_TYPE      "TEENSY 4.0"
  #elif ( defined(__MKL26Z64__) || defined(ARDUINO_ARCH_AVR) )
  #define BOARD_TYPE      "TEENSY LC or 2.0"
  #else
  #define BOARD_TYPE      "TEENSY 3.X"
  #endif
#else
  // For Mega
  #define BOARD_TYPE      "AVR Mega"
#endif
#include <SPI.h>
// Use true  for ENC28J60 and UIPEthernet library (https://github.com/UIPEthernet/UIPEthernet)
// Use false for W5x00 and Ethernetx library      (https://www.arduino.cc/en/Reference/Ethernet)
//#define USE_UIP_ETHERNET   true
#include <EthernetWebServer.h>
// Enter a MAC address and IP address for your controller below.
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
// Select the IP address according to your local network
IPAddress ip(192, 168, 2, 200);
EthernetWebServer server(80);
const int led = 13;
void handleRoot()
  server.send(200, "text/plain", "Hello from EthernetWebServer");
void handleNotFound()
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i=0; i<server.args(); i++)
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  digitalWrite(led, 0);
void setup(void)
  Serial.println("\nStarting HelloServer on " + String(BOARD_TYPE));
  // start the ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.on("/", handleRoot);
  server.on("/inline", [](){
    server.send(200, "text/plain", "This works as well");
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.print(F("HTTP EthernetWebServer is @ IP : "));
  Serial.println(Ethernet.localIP());
void loop(void)
  server.handleClient();
HI
I am using and arduino due with SIM900 Shield and i am having problem with GPRS_Shield_Arduino.h and SofwareSerial.h library, seem is not compatible with due, there are a solution for use SIM900 shield with due?
Thanks in advance
@mtorruella provide code and what is your actual error.
HI nitrof¡¡¡
I don't have any specific code error, I was working with arduino MEGA 2560 + SIM900 Shield, I did'nt have any problems with this platform, i was using GPRS_Shield_Arduino.h and did my life easier interfasing wiht SIM900, I did not have to use AT commands.
I had some issues with MEGA sdram capacity, then I have to move to the Arduino DUE, the GPRS_Shield_Arduino.h is not compatible with DUE, because of that, I am looking for a new library compatible with DUE how can help me interfasing with SIM900 without the need to use AT commands.
Thanks for your help¡¡¡¡
mtorruella: HI
Thanks in advance
Hi there @mtorruella,
Using SoftwareSerial with the DUE is not possible, this is a library which is not compatible with Arduino DUE's ATSAM3X8E microcontroller. As an alternative you should use any of the hardware serial ports available in the DUE, or the software serial library for the DUE soft_uart, available at https://github.com/antodom/soft_uart.
I hope it helps.
Hi antodom
I will try with soft_uart Thanks!!!!!
Hello there,
I have a program that I run with mega. I can’t run this program with DUE. When I load the Nextion screen library it gives an error in compilation. what is the solution to this.
error message;
Arduino:1.8.12 (Windows 10), Kart:“Arduino Due (Programming Port)”
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:285:2: error: #error This version of SoftwareSerial supports only 20, 16 and 8MHz processors
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp: In member function ‘bool SoftwareSerial::listen()’:
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:341:23: error: ‘SREG’ was not declared in this scope
uint8_t oldSREG = SREG;
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:342:9: error: ‘cli’ was not declared in this scope
cli();
In file included from C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/Arduino.h:201:0,
from C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:43:
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp: In member function ‘void SoftwareSerial::setTX(uint8_t)’:
C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\variants\arduino_due_x/variant.h:63:65: error: invalid conversion from ‘Pio*’ to ‘uint8_t {aka unsigned char}’ [-fpermissive]
#define digitalPinToPort(P) ( g_APinDescription[P].pPort )
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:517:18: note: in expansion of macro ‘digitalPinToPort’
uint8_t port = digitalPinToPort(tx);
C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\variants\arduino_due_x/variant.h:66:44: error: base operand of ‘->’ is not a pointer
#define portOutputRegister(port) ( &(port->PIO_ODSR) )
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:518:27: note: in expansion of macro ‘portOutputRegister’
_transmitPortRegister = portOutputRegister(port);
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp: In member function ‘void SoftwareSerial::setRX(uint8_t)’:
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:528:18: note: in expansion of macro ‘digitalPinToPort’
uint8_t port = digitalPinToPort(rx);
C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\variants\arduino_due_x/variant.h:67:44: error: base operand of ‘->’ is not a pointer
#define portInputRegister(port) ( &(port->PIO_PDSR) )
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:529:26: note: in expansion of macro ‘portInputRegister’
_receivePortRegister = portInputRegister(port);
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp: In member function ‘void SoftwareSerial::begin(long int)’:
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:540:31: error: ‘table’ was not declared in this scope
for (unsigned i=0; i<sizeof(table)/sizeof(table[0]); ++i)
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:556:38: error: ‘digitalPinToPCICR’ was not declared in this scope
if (digitalPinToPCICR(_receivePin))
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:558:78: error: ‘digitalPinToPCICRbit’ was not declared in this scope
*digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin));
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:558:79: error: ‘_BV’ was not declared in this scope
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:559:37: error: ‘digitalPinToPCMSK’ was not declared in this scope
*digitalPinToPCMSK(_receivePin) |= _BV(digitalPinToPCMSKbit(_receivePin));
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:559:78: error: ‘digitalPinToPCMSKbit’ was not declared in this scope
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp: In member function ‘void SoftwareSerial::end()’:
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:574:36: error: ‘digitalPinToPCMSK’ was not declared in this scope
if (digitalPinToPCMSK(_receivePin))
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:575:77: error: ‘digitalPinToPCMSKbit’ was not declared in this scope
*digitalPinToPCMSK(_receivePin) &= ~_BV(digitalPinToPCMSKbit(_receivePin));
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:575:78: error: ‘_BV’ was not declared in this scope
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp: In member function ‘virtual size_t SoftwareSerial::write(uint8_t)’:
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:610:21: error: ‘SREG’ was not declared in this scope
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:611:7: error: ‘cli’ was not declared in this scope
cli(); // turn off interrupts for a clean txmit
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:615:26: error: ‘XMIT_START_ADJUSTMENT’ was not declared in this scope
tunedDelay(_tx_delay + XMIT_START_ADJUSTMENT);
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp: In member function ‘virtual void SoftwareSerial::flush()’:
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:658:21: error: ‘SREG’ was not declared in this scope
C:\Users\User\Documents\Arduino\libraries\SoftwareSerial-master\SoftwareSerial.cpp:659:7: error: ‘cli’ was not declared in this scope
cli();
exit status 1
Arduino Due (Programming Port) kartı için derleme hatası.
“Show verbose output during compilation”
option enabled in File → Preferences.
Hi hasanturgut.
First, you should have start a new tread for your question.
second, put any code or error text into code brace ( look up the </> )
Third, you should also post any code you have.
By now, I can tell that softwareSerial do not support DUE.
Whit DUE, you can use build in serial port without using softwareSerial. just use Serial1 to 3.
But again, without code, can’t tell more.
Regards.
Nitrof
Hi Antodom, I'm trying to use your soft_uart library and am having a problem. I have a data logging program which logs data from various sensors, and am trying to use a soft serial to send some data back to a PC for testing purposes. I based the code for the soft_uart on one of the examples supplied.
After the serial declaration section:
include "soft_uart.h"
using namespace soft_uart; using namespace soft_uart::arduino_due;
define RX_PIN 53 // software serial port's reception pin
define TX_PIN 51 // software serial port's transmision pin
define SOFT_UART_BIT_RATE 57600 // 57600 38400 1200 19200 9600 115200 300
define RX_BUF_LENGTH 16 // software serial port's reception buffer length
define TX_BUF_LENGTH 64 // software serial port's transmision buffer length
// declaration of software serial port object serial_tc4 // which uses timer/counter channel TC4 serial_tc4_declaration(RX_BUF_LENGTH,TX_BUF_LENGTH); auto& serial_con=serial_tc4; // serial_tc4_t& serial_obj=serial_tc4; Serial Console
which is straight from the example, I have:
define NUM_TRS 4
typedef struct { char data[NUM_TRS][8]; HardwareSerial *serial[NUM_TRS]; } tr_sense; tr_sense tRange;
then further down the code I decalare a function:
int LogData(tr_sense *data, double temp, double temp2) { ... }
The compiler complains that 'tr_sense was not declared in this scope'.
If I comment out the soft_uart declaration lines:
//serial_tc4_declaration(RX_BUF_LENGTH,TX_BUF_LENGTH); //auto& serial_con=serial_tc4; // serial_tc4_t& serial_obj=serial_tc4; Serial Console
everything comiles and works ok, obviously without soft_uart functionality. I'm a bit lost at this point. Please help...
Thank you for writing the library anyway, especially if I can get it to work in my code :)
Apologies, but my last post on difficulties on using the soft_uart library, didn't supply information on what board I was trying to use.
I am using the Arduino DUE board.
I have tried searching the forum on this error but didn't find anything relevant to this specific situation.
HI there @steveit,
I would need to have a look to your whole example and the compiler output for being of any help.
Best regards.
Hi Antodom,
Pretty much what you saw in the post will reproduce the issue:
#include "soft_uart.h"
#define RX_PIN 53 // software serial port's reception pin
#define TX_PIN 51 // software serial port's transmision pin
#define SOFT_UART_BIT_RATE 57600 // 57600 38400 1200 19200 9600 115200 300
#define RX_BUF_LENGTH 16 // software serial port's reception buffer length
#define TX_BUF_LENGTH 64 // software serial port's transmision buffer length
#define NUM_TRS 4
typedef struct {
  //HardwareSerial *serial[NUM_TRS];
} tr_sense;
tr_sense tRange;
int LogData (tr_sense *data, double temp, double temp2) {
 return(0);
The program I have here as a whole has a lot more code in it to read sensors from the 4 hardware serial ports, a couple of SPI sensors and an IIC RTC, but this basic framework code will reporoduce the issue.
The compiler output is:
soft_uart_test:26: error: 'tr_sense' was not declared in this scope
soft_uart_test:26: error: 'data' was not declared in this scope
soft_uart_test:26: error: expected primary-expression before 'double'
soft_uart_test:26: error: expression list treated as compound expression in initializer [-fpermissive]
C:\Users\S.Bassett\Documents\Arduino\soft_uart_test\soft_uart_test.ino: In function 'int LogData(tr_sense*, double, double)':
soft_uart_test:26: error: 'int LogData(tr_sense*, double, double)' redeclared as different kind of symbol
soft_uart_test:26: error: previous declaration of 'int LogData'
exit status 1
Where is says "soft_uart_test:26: error: previous declaration of 'int LogData'", no matter what name I give the function it gives this output with the new name.
Thanks for your reply
Hi there again @steveit,
I suspect the Arduino IDE is seeing the prototype of function logData() before seeing the struct definition. Try if including struct tr_sense definition before the definition of soft_uart objects solve the problem.
Best.
try not typedef it:
struct tr_sense{
tr_sense tRange;
Hi Antodom,
That got rid of the error, thank you. I've been shoved in the deep end with this project, as a software developer from a couple of decades ago and out of practice.
Also thanks for the reply from nitrof, something else to bear in mind.
Thanks again.
