I am trying to read images from a non-FIFO OV7670 to a Arduino Due and then save them to an SD card. I figured that if an Arduino Uno could read the module then send the pictures to the computer (http://forum.arduino.cc/index.php/topic,159557.0.html) the Due would be able to. However as a preliminary test i have my program counting pixels and the number of pixels per row is wrong. It is not 1280 bytes or 640 pixels as it should be. My code is able to very accurately read the number of rows per frame (480). See attached code.
I do not have the SIOD or SIOC pins connected as i am okay with the default image. However i will connect them if they will help me be able to capture the pixels.
Some poeple say that you need some kind of SRAM in order to capture the images. How does this help? wouldn’t the images first have to be sent to the Arduino and then finally to the External SRAM?
Arduino Due is faster than Uno, but it is not fast enaugh. I think it is better not to use interrupts and setup camera. It has paramerts like devider/prescaler which changes input clock.
