hallo
hab seit einigen tagen einen arduino due.
- tests ok
da ich von parallax-propeller-mc komme, habe ich einige sensoren, unteranderem einen
ping - sensor. mit 3 pins (+,gnd,signal)
heute wollte ich mal mein 1. sketch fuer den ping schreiben (ist uebertrieben, eher copy and paste)
compile sketch ok
run: mit seriellen monitor auch ok, aber output ist 0in, 0cm
* Ping))) Sensor
* dd. 03.05.2013
* name: sketch-due-ping1.txt
* Ref. it's for the arduinoDue
* changing from the orig.digitalPin 07 to
* due digitalPin22
This sketch reads a PING))) ultrasonic rangefinder and returns the
distance to the closest object in range. To do this, it sends a pulse
to the sensor to initiate a reading, then listens for a pulse
to return. The length of the returning pulse is proportional to
the distance of the object from the sensor.
The circuit:
* +V connection of the PING))) attached to +5V
* GND connection of the PING))) attached to ground
* SIG connection of the PING))) attached to digital pin 22
http://www.arduino.cc/en/Tutorial/Ping
created 3 Nov 2008
by David A. Mellis
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
// this constant won't change. It's the pin number
// of the sensor's output:
const int pingPin = 22 // old:7;
// initialize serial communication:
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(100);
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
2.sketch
const int signal=22;
int distance;
unsigned long pulseduration=0;
pinMode(signal, OUTPUT);
void measureDistance()
// set pin as output so we can send a pulse
// set output to LOW
digitalWrite(signal, LOW);
// now send the 5uS pulse out to activate Ping)))
digitalWrite(signal, HIGH);
// now we need to change the digital pin
// to input to read the incoming pulse
pinMode(signal, INPUT);
// finally, measure the length of the incoming pulse
pulseduration=pulseIn(signal, HIGH);
// get the raw measurement data from Ping)))
measureDistance();
// divide the pulse length by half
pulseduration=pulseduration/2;
// now convert to centimetres. We're metric here people...
distance = int(pulseduration/29);
// Display on serial monitor
Serial.print("Distance - ");
Serial.print(distance);
Serial.println(" cm");
beide sketches laufen, hab im augenblick keine ahnung warum der output immer 0 ist?
fuer hinweise und hilfe waere ich dankbar
gruesse nomad
