My first pass at a pinout diagram here for those interested in such matters
Rob
Rob
Nantonos:
Please report any errors, and I will fix them.
Colors indicate comparison to the Mega2560 which has a similar shield connector pinout. Green means the same as Mega2560. Red is for warnings. Orange shows new functionality:
- JTAG and SWD headers for debugging
- DAC outputs
- CAN bus
- Two USB ports
- erase switch
Please ignore the interrupt pins for now, these are not implemented in 1.5 but are planned for 1.5.1 so I will leave them where they are for the moment and revise when 1.5.1 comes out.
revision 2: correct labelling of USB ports, SPI not ICSP header.
revision 3: label JTAG and SWD pins, call out 16U2 ICSP (thanks to PeterVH)The definitive source remains the official Arduino Due hardware page. This pinout photo overlay is just for convenience.
Btw. the Vcc on the SPI is 5V and should be noticed
Markus_L811:
On the spi in the middle?, SHIT!, And I have been using this and that.
How can I know if my board is defunct or not ?
I was attaching an unit that is supposed to handle 3v3 and 5v, but I tried mosi++ in the middle, and the same on the edge of the board.
Mixing 5v and 3v3 on an board that is not 5v tolerant is not very nice design!
neslekkim:
Markus_L811:
Btw. the Vcc on the SPI is 5V and should be noticedOn the spi in the middle?, SHIT!, And I have been using this and that.
I was attaching an unit that is supposed to handle 3v3 and 5v, but I tried mosi++ in the middle, and the same on the edge of the board.Mixing 5v and 3v3 on an board that is not 5v tolerant is not very nice design!
Yes saw it on this http://arduino.cc/en/uploads/Main/arduino-Due-schematic.pdf.
It's true not an good move to have 5V on an 3.3V SPI some Sparcfun Shields use this Pin to detect the voltage too so they are dangerous too. Can you explain an bit more what are you have done so I can think about it.
But it musst be possible too set each Pin high and low seperatly so you can detect if it works and you can use the pins as intput to check the other way. --> Serial echo
Markus_L811:
Yes saw it on this http://arduino.cc/en/uploads/Main/arduino-Due-schematic.pdf.It's true not an good move to have 5V on an 3.3V SPI some Sparcfun Shields use this Pin to detect the voltage too so they are dangerous too. Can you explain an bit more what are you have done so I can think about it.
I have been trying to get an spi 7segment display running, and have tried all variations on the spi outputs, nothing worked, and sometimes I got an segment of an digit lighting, everything was very flakey.
Really hope that I didn't break the Due with this. I tried to use gnd+vcc from the spi next to the SAM, and tried mosi, ss, spck etc from that header, and the headers around the board, nothing worked. Wery close to throwing the crap in the shredder..
Luckily Graynomad is now creating an proper pinout map for this board, so I will try again in the weekend.
Markus_L811:
Good point, agreed.
That may not be right :), it needs people to check it.
Rob
Well it is a lot better than mine, I would say.
I added an obsoletion notice to the first post in this thread, with a link to yours.
Hi Nantonos,
I hope I didn't step on your toes there, I just thought that after bagging Arduino documentation for ages I should actually contribute something and went for it.
BTW I haven't added the interrupts yet, I'll grab them off your drawing but still need to verify. Where did you get the data from, I seem to remember we had a thread about this but I can't find anything in Winterrupts.c or.h
Rob
Graynomad:
Hi Nantonos,I hope I didn't step on your toes there,
No! Not at all. I did mine because I had already done one for the Mega2560, the Due had been (finally) announced that day and I had ordered one from the shop. So I took my photoshop file for the Mega2560, swapped in the Due photo, and then modified it based on what info was available then.
And the reason I did it was because the official documentation was lacking and I thought it would help others as well as myself. That is the point, right? And yours adds a lot more detail, and is much better - well done! The community benefits.
I wanted to be sure that anyone who came across this thread (by Google search, etc) got directed to the better source of information.
Graynomad:
I just thought that after bagging Arduino documentation for ages I should actually contribute something and went for it.BTW I haven't added the interrupts yet, I'll grab them off your drawing but still need to verify. Where did you get the data from, I seem to remember we had a thread about this but I can't find anything in Winterrupts.c or.h
I am not sure about the interrupts on that drawing (as it says in the first post). And Massimo said the interrupts were not supported in 1.5.0 (which is why you can't find it) so I had intended to come back to that once they had it implemented and there was a .h file to look at.
Yes I looked in the code and they aren't supported yet, I think there has been some work done in that area though, I may have to look in the Git repo.
In the attachInterrupt() reference page it says
Parameters
interrupt: the number of the interrupt (int)pin: the pin number (Arduino Due only)
Which implies every pin, and in fact that is possible with the SAM if someone writes the code.
Rob
Just found the thread, yes every pin can be used for interrupts.
Rob
