Arduino Due plays audio with cell phone speaker?
I am trying to do a project in conjunction with several sensors and in the mode of wanting to reproduce an audio from a micro sd for an alarm, I bought a speaker from a cell phone and when connecting to the DAC output of the arduino Due the audio has a very low volume so I want to know if an amplifier circuit is needed for this type of speaker.
Also for misinformation I bought a speaker grove:
images
and I tried to play audio but I hear a lot of static and the audio itself sounds very low, so I would like to know if someone knows how to do to have a relatively loud and clear audio Thanks
the code used is the same test code of Arduino Due Audio, I attach it
#include <SD.h>
  #include <SPI.h>
  #include <Audio.h>
  const int chipSelect = 53;
  int count = 1;
  const int S = 1024; // Number of samples to read in block
  int volume = 1024;
    // debug output at 9600 baud
    // setup SD-card
    Serial.print("Initializing SD card...");
    pinMode(4,OUTPUT);
    if (!SD.begin(chipSelect)) {
      Serial.println(" failed!");
      while(true);
    Serial.println(" done.");
    // hi-speed SPI transfers
    // 44100kHz stereo => 88200 sample rate
    // 100 mSec of prebuffering.
    Audio.begin(88200, 100);
    // open wave file from sdcard
    File myFile = SD.open("test.wav");
    if (!myFile) {
      // if the file didn't open, print an error and stop
      Serial.println("error opening test.wav");
      while (true);
    short buffer[S];
    Serial.print("Playing");
    // until the file is not finished
    while (myFile.available()) {
      // read from the file into buffer
      myFile.read(buffer, sizeof(buffer));
      // Prepare samples
      Audio.prepare(buffer, S, volume);
      // Feed sampletks to audio
      Audio.write(buffer, S);
      // Every 100 block print a '.'
      count++;
      if (count == 100) {
        Serial.print(".");
        count = 0;
    myFile.close();
    Serial.println("End of file. Thank you for listening!");
    while (true) ;
Moderador:
Por favor, lee las Normas del foro y no publiques la misma pregunta por cuanta sección e idioma encuentres.
Acabas de cometer un doble posteo o cross post.
Este hilo permanecerá cerrado y luego será borrado.
