Arduino Due problem/ Serial Monitor Takes amount but goes crazy!
Hi all
Here is the code for Arduino Due:
volatile boolean l;
//unsigned int integerValue=0;  // Max value is 65535
//char incomingByte;
void TC0_Handler()
    long dummy=REG_TC0_SR0; // vital - reading this clears some flag    --- Status REG
                            // otherwise you get infinite interrupts
    l= !l;
    //REG_TC0_CCR0=0b101; //Start counter
//void setFrequen
void setup(){
  Serial.begin(57600);
  pinMode(13,OUTPUT);
void loop(){
       digitalWrite(13,l);
 if (Serial.available() > 0) {   // something came across serial
   char buffer[] = {' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL'};
 Serial.readBytesUntil('\n', buffer, 20);
int  incomingValue = atoi(buffer);
   Serial.println(incomingValue);
   pinMode(2,OUTPUT);    // port B pin 25
  analogWrite(2,255);
   REG_PIOB_PDR = 1<<25; // disable PIO, enable peripheral
  REG_PIOB_ABSR= 1<<25;
     REG_TC0_CMR0=0b00000000000010011100010000000000;
  REG_TC0_IER0=0b00010000;
  REG_TC0_RC0 = incomingValue*1000000;
  NVIC_EnableIRQ(TC0_IRQn);
When I change the amount of " REG_TC0_RC0" by increasing the number for example from 1 -20 it goes properly
but when I come back to the “1” for example
1
8
1
It takes time to change the blinking time.
What do you think?
Do I need to initialize any other REG to have this job done?
Is my Serial Monitor adjusted properly?
Thanks for your guide in advance.
