Arduino Due : Problem to use the Programming Port .
Are there any solutions to use Programming Port with Os Mac? :o
because I red this :
After spending a solid week of my precious free time going through at least 30 different solutions trying to install /dev/tty.usbmodemXXXX The best I was able to do was program 'blink' with /dev/cu.usbmodemXXXX. Any other program fails miserably.
I finally solved the problem. I bought a cheap PC to program the Arduino. Thanks Apple!!! > /
I can transfer Sketches with the USB Native Port but in this way I can't use the Serial Monitor.
My Mac have more or less recognize Arduino Due (because it recognized it when I used the USB Native Port) but it's not set up at all, but the Arduino tutorial says it's normal.
So, should I re install my os entirely for example?
I see you posted this in the Create > Editor forum section. Have you determined that this problem is isolated to Arduino Web Editor, or does it also occur when using the standard version of the Arduino IDE?
I made mistake by posting this message. It should be in troubleshooting.
My MacBook Pro can't recognize the Arduino even in Network Preferences, whereas it could before.
Pffff I'm gonna test something else
