Hello,
I am a newby in Arduino and sorry for asking questions like this.
So far I, tried to get a PWM signal with 80% Duty Cycle (=204) and a frequency of 60000Hz.
I don't know how to change register entries in the SAMX3E8. Do you have an example for the DUE or can me help anyhow?
The program is below.
Best,
Mike
Above approximately 40khz, I notice that what is commanded is not what is received. You just need to adjust the programmed frequency to get what you need. I test several values, and this is what happens:
and find out, that i have to set the values DIVA and PREA in PMW_CLK on address 0x40094000.
DIVA is working, but PREA is not changing anything. Do I make a mistake with the address?
#define DIVA (*(volatile unsigned int ) 0x40094000) #define PREA ((volatile unsigned int *) 0x40094008)
#define WPSWS0 (*(volatile unsigned int ) 0x400940E8) #define WPHWS0 ((volatile unsigned int *) 0x400940F0)
You don’t need to #define anything, its all predefined in the system. The best place
to learn about driving PWM is the libsam includes and sources:
In your Arduino distribution go to …/hardware/arduino/sam/system/libsam/source/pwmc.c
and …/hardware/arduino/sam/system/libsam/include/pwmc.h
[edit: after a bit of delving, this sets up PWM channel 0 to drive Arduino pin 34:
pmc_enable_periph_clk (PWM_INTERFACE_ID) ; // turn on clocking to PWM unit
PWMC_ConfigureChannel (PWM, 0, 1, 0, 0) ; // PWM channel 0, clock = MCLK/2 = 42MHz
PWMC_SetPeriod (PWM, 0, 700) ; // period = 700 pwm clocks (60kHz)
PWMC_SetDutyCycle (PWM, 0, 80*700/100) ; // duty set to 80%
PWMC_EnableChannel (PWM, 0) ; // enable
// Configure pin 34 (PC2) to be driven by peripheral B (PWM channel 0 L)
PIOC->PIO_PDR = 1<<2 ; // disable PIO control
PIOC->PIO_IDR = 1<<2 ; // disable PIO interrupts
PIOC->PIO_ABSR |= 1<<2 ; // switch to B peripheral
Hello,
i want to generate a PWM wave having a period of 20 ms, with a pulse being ON for 1ms to 2ms. I have used the above code of PWMC controller of SAM3X8E for getting the result, but i am not getting the desired output.
I have used 84MHz clock with a pre-scaler of 2. The frequency is 50Hz.
PWMC_ConfigureChannel (PWM, 7, 2, 0, 0) ; //on channel 7 of PWM and pin 6 of Due
PWMC_SetPeriod (PWM, 7, 840000); //84Mhz/2/50
PWMC_SetDutyCycle (PWM, 7, 50*840000/100) ;
On the Oscilloscope, i am getting a 1.5 ms pulse but the period is not about 20ms. Can anybody please have a look at this issue.
You got it Right, i want to control a 180 degree servo motor having it's neutral at 90 degree. By giving a pulse of 1ms to 2ms, i want it to rotate it to 90 degree and then again back to 180 degree.
i have already referred to the servo library of Arduino, but i want it to be controlled using PWM Controller of SAM 3X8E. Till now i have studied that a servo requires a pulse every 20 ms, independent of what is duty cycle or the on time.
I have the requirement to generate a pulse of 1.5ms at a frequency of 50Hz and then pulse should be off for around 18 ms. If the frq. is 50Hz, then the period should be 20ms, but after coding, in the oscilloscope, i am not getting a period of 20ms. Also, i am confused regarding what should be the pre-scaler value to be used in Due to pre-scale the clock of 84Mhz, and the calculation of the period done in the PWMC_SetPeriod function.
PWMC.c is the source file which i am referring for all this purpose.
