Excuse me! I would like to output PWM with this program, what program do I need to add? Also, I would like to introduce a carrier wave from the value read by the current sensor. Please help!
#define LED_PIN 13
#include<math.h>
float a[200];//u
float b[200];//v
float c[200];//w
int n=0;
int p=0;
int x = 0, y=0, z=0, w=0, t=0 ;
double average = 0 ;
double average1 = 0 ;
float value1 = 0;
float volt1 = 0;
float current1 = 0;
float value2 = 0;
float volt2 = 0;
float current2 = 0;
float value3 = 0;
float volt3 = 0;
float current3 = 0;
void setup(){
tc_setup();
adc_setup();
pwm_setup();
pinMode(LED_PIN,OUTPUT);
/************* Timer Counter 0 Channel 2 to generate PWM pulses thru TIOA2 ************/
void tc_setup() {
PMC->PMC_PCER0 |= PMC_PCER0_PID27; //TC2 power ON : Timer Counter 0 channel 2 IS TC2
TC0->TC_CHANNEL[2].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC2 counter and enable
void adc_setup() {
pmc_set_writeprotect(false); // PMC controller write protection disable.
PMC->PMC_PCER1 |= PMC_PCER1_PID37; // ADC power on
ADC->ADC_CR = ADC_CR_SWRST; // Reset ADC
ADC->ADC_MR = ADC_MR_TRGEN_EN // Hardware trigger select
| ADC_MR_TRGSEL_ADC_TRIG5 // Trigger by PWM Event Line 1
| ADC_MR_PRESCAL(1);
ADC->ADC_CHER = ADC_CHER_CH7 | ADC_CHER_CH6 | ADC_CHER_CH5; // Enable Channel 7
NVIC_EnableIRQ(ADC_IRQn); // Enable ADC interrupt
ADC->ADC_IER = ADC_IER_EOC7; // End Of Conversion interrupt enable for channel 7
void pwm_setup(){
REG_PMC_PCER1 |= PMC_PCER1_PID36;
uint16_t CounterPeriod;
uint16_t DeadTime;
REG_PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(1);
CounterPeriod = 16800; //84MHz/5KHz = 16800
DeadTime = 100;
REG_PWM_CPRD0 = CounterPeriod;
REG_PWM_CPRD1 = CounterPeriod;
REG_PWM_CPRD2 = CounterPeriod;
REG_PWM_CPRD3 = CounterPeriod;
//REG_PWM_CDTY1 = 21000; //Channel Duty Cycle Register
REG_PWM_CMR0 = PWM_CMR_CALG | PWM_CMR_CPRE_MCK; //CALG senter Alg
REG_PWM_CMR1 = PWM_CMR_DTE | PWM_CMR_CALG | PWM_CMR_CPRE_MCK;
REG_PWM_CMR2 = PWM_CMR_DTE | PWM_CMR_CALG | PWM_CMR_CPRE_MCK;
REG_PWM_CMR3 = PWM_CMR_DTE | PWM_CMR_CALG | PWM_CMR_CPRE_MCK;
REG_PWM_DT1 = PWM_DT_DTH(DeadTime) | PWM_DT_DTL(DeadTime);
REG_PWM_DT2 = PWM_DT_DTH(DeadTime) | PWM_DT_DTL(DeadTime);
REG_PWM_DT3 = PWM_DT_DTH(DeadTime) | PWM_DT_DTL(DeadTime);
REG_PIOC_PDR = PIO_PDR_P9 | PIO_PDR_P8 | PIO_PDR_P7 | PIO_PDR_P6 | PIO_PDR_P5 | PIO_PDR_P4;
REG_PIOC_ABSR |= PIO_ABSR_P9 | PIO_ABSR_P8 | PIO_ABSR_P7 | PIO_ABSR_P6 | PIO_ABSR_P5 | PIO_ABSR_P4;
PWM->PWM_CMP[0].PWM_CMPM = PWM_CMPM_CEN;
PWM->PWM_ELMR[1] = PWM_ELMR_CSEL0;
PWM->PWM_CMP[0].PWM_CMPV = PWM_CMPV_CV(CounterPeriod - 10);
NVIC_EnableIRQ(TC2_IRQn); // TC2 NVIC enable
NVIC_SetPriority(PWM_IRQn, 0);
NVIC_EnableIRQ(PWM_IRQn);
PWM->PWM_ENA |= PWM_ENA_CHID0 | PWM_ENA_CHID0;
PWM->PWM_IER1 |= PWM_IER1_CHID0;
REG_PWM_IER1 = PWM_IER1_CHID0; // Interrupt on PWM Channel 0 counter
void loop(){
if(x==2199){
for(int u=0 ;u>=0 && u<=199;u=u+1){
Serial.print("U相電流 : ");
Serial.println(a[u]);
for(int v=0 ;v>=0 && v<=199;v=v+1){
Serial.print("V相電流 : ");
Serial.println(b[v]);
for(int w=0 ;w>=0 && w<=199;w=w+1){
Serial.print("W相電流 : ");
Serial.println(c[w]);
void PWM_Handler(){
if (REG_PWM_ISR1 & PWM_ISR1_CHID0) // Check if an update condition has occured
ADC_Handler();
void ADC_Handler(){
value1 = ADC->ADC_CDR[7];
value2 = ADC->ADC_CDR[6];
value3 = ADC->ADC_CDR[5];
//電流センサ計算部分//
volt1 = ((value1-17)*(3.3/ 4095.0)) ;
volt2 = ((value2-17)*(3.3/ 4095.0)) ;
volt3 = ((value3-17)*(3.3/ 4095.0)) ;
current1 = ((volt1 - 2.5)*40) ;
current2 = ((volt2 - 2.5)*40) ;
current3 = ((volt3 - 2.5)*40) ;
//配列に値を格納//
x++;
if(2000<=x && x<=2199){
//A/D変換の値を格納//
a[y] = value1;
b[z] = value2;
c[w] = value3;
//電流値を格納//
/* a[y] = current1;
b[z] = current2;
c[w] = current3;*/
y++;
z++;
w++;
//PIOB->PIO_ODSR ^= PIO_ODSR_P27; //Lチカ用
if(n%2==0){
digitalWrite(LED_PIN,HIGH);
n++;
}else{
digitalWrite(LED_PIN,LOW);
n++;
