Arduino Due Reset Button Does Nothing...LCD TFT Display Doing Nothing...
Hey Guys,
I have this 7" LCD Screen (http://www.ebay.com/itm/7-7-0-inch-TFT-LCD-module-CPLD-SDRAM-800x480-arduino-DUE-MEGA2560-4-3-SSD1963/121186426608?_trksid=p2050601.c100272.m3467&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140813112422%26meid%3D6d15b18ac3014739999cbf2992d05fd2%26pid%3D100272%26prg%3D20140813112422%26rk%3D2%26rkt%3D4%26sd%3D111393672033%26clkid%3D130143396548825626&_qi=RTM1562570)
hooked up to this breakout board (http://www.ebay.com/itm/TFT-SD-Shield-for-Arduino-DUE-TFT-LCD-Module-SD-Card-Adapter-2-8-3-2-inch-Mega-/121057447668?)
hooked up to the Arduino Due R3 board.
I’m using the UTFT library and 800x480 example from here: Electronics - Henning Karlsen
Here’s what I’ve done:
  1. I was able to successfully upload this code:
// UTFT_Demo_800x480 (C)2014 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of how to use most of the functions
// of the library with a supported display modules.
// This demo was made for modules with a screen resolution
// of 800x480 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Set the pins to the correct ones for your development shield
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due       : <display model>,25,26,27,28
// Teensy 3.x TFT Test Board                   : <display model>,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : <display model>,22,23,31,33
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(ITDB50,38,39,40,41);
  randomSeed(analogRead(0));
// Setup the LCD
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  int buf[798];
  int x, x2;
  int y, y2;
  int r;
// Clear the screen and draw the frame
  myGLCD.clrScr();
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 799, 13);
  myGLCD.setColor(64, 64, 64);
  myGLCD.fillRect(0, 466, 799, 479);
  myGLCD.setColor(255, 255, 255);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
  myGLCD.setBackColor(64, 64, 64);
  myGLCD.setColor(255,255,0);
  myGLCD.print("<http://electronics.henningkarlsen.com>", CENTER, 467);
  myGLCD.setColor(0, 0, 255);
  myGLCD.drawRect(0, 14, 799, 465);
// Draw crosshairs
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.drawLine(399, 15, 399, 464);
  myGLCD.drawLine(1, 239, 798, 239);
  for (int i=9; i<790; i+=10)
    myGLCD.drawLine(i, 237, i, 242);
  for (int i=19; i<470; i+=10)
    myGLCD.drawLine(397, i, 402, i);
// Draw sin-, cos- and tan-lines
  myGLCD.setColor(0,255,255);
  myGLCD.print("Sin", 5, 15);
  for (int i=1; i<798; i++)
    myGLCD.drawPixel(i,239+(sin(((i*1.13)*3.14)/180)*200));
  myGLCD.setColor(255,0,0);
  myGLCD.print("Cos", 5, 27);
    myGLCD.drawPixel(i,239+(cos(((i*1.13)*3.14)/180)*200));
  myGLCD.print("Tan", 5, 39);
    myGLCD.drawPixel(i,239+(tan(((i*0.9)*3.14)/180)));
  delay(2000);
  myGLCD.setColor(0,0,0);
  myGLCD.fillRect(1,15,798,464);
// Draw a moving sinewave
  x=1;
  for (int i=1; i<(798*20); i++)
    x++;
    if (x==799)
      x=1;
    if (i>799)
      if ((x==399)||(buf[x-1]==239))
        myGLCD.setColor(0,0,255);
      myGLCD.drawPixel(x,buf[x-1]);
    y=239+(sin(((i*1.65)*3.14)/180)*(200-(i / 100)));
    myGLCD.drawPixel(x,y);
    buf[x-1]=y;
  delay(2000);
// Draw some random filled rectangles
  for (int i=0; i<50; i++)
    myGLCD.setColor(random(255), random(255), random(255));
    x=2+random(746);
    y=16+random(397);
    x2=x+50;
    y2=y+50;
    myGLCD.fillRect(x, y, x2, y2);
  delay(2000);
// Draw some random filled, rounded rectangles
    x=2+random(746);
    y=16+random(397);
    x2=x+50;
    y2=y+50;
    myGLCD.fillRoundRect(x, y, x2, y2);
  delay(2000);
// Draw some random filled circles
    x=27+random(746);
    y=41+random(397);
    myGLCD.fillCircle(x, y, 25);
  delay(2000);
// Draw some lines in a pattern
  myGLCD.setColor (255,0,0);
  for (int i=15; i<463; i+=5)
    myGLCD.drawLine(1, i, (i*1.66)-10, 463);
  for (int i=463; i>15; i-=5)
    myGLCD.drawLine(798, i, (i*1.66)+30, 15);
  myGLCD.setColor (0,255,255);
    myGLCD.drawLine(1, i, 770-(i*1.66), 15);
    myGLCD.drawLine(798, i, 810-(i*1.66), 463);
  delay(2000);
// Draw some random circles
  for (int i=0; i<250; i++)
    x=32+random(736);
    y=45+random(386);
    r=random(30);
    myGLCD.drawCircle(x, y, r);
  delay(2000);
// Draw some random rectangles
    x=2+random(796);
    y=16+random(447);
    x2=2+random(796);
    y2=16+random(447);
    myGLCD.drawRect(x, y, x2, y2);
  delay(2000);
// Draw some random rounded rectangles
    x=2+random(796);
    y=16+random(447);
    x2=2+random(796);
    y2=16+random(447);
    myGLCD.drawRoundRect(x, y, x2, y2);
  delay(2000);
    x=2+random(796);
    y=16+random(447);
    x2=2+random(796);
    y2=16+random(447);
    myGLCD.drawLine(x, y, x2, y2);
  delay(2000);
  for (int i=0; i<10000; i++)
    myGLCD.drawPixel(2+random(796), 16+random(447));
  delay(2000);
  myGLCD.fillScr(0, 0, 255);
  myGLCD.fillRoundRect(320, 190, 479, 289);
  myGLCD.print("That's it!", CENTER, 213);
  myGLCD.print("Restarting in a", CENTER, 239);
  myGLCD.print("few seconds...", CENTER, 252);
  myGLCD.setColor(0, 255, 0);
  myGLCD.setBackColor(0, 0, 255);
  myGLCD.print("Runtime: (msecs)", CENTER, 450);
  myGLCD.printNumI(millis(), CENTER, 465);
  delay (10000);
  1. I tried changing this line: UTFT myGLCD(ITDB50,38,39,40,41);
    to the following and got nothing to happen: UTFT myGLCD(CTE50, 25,26,27,28) and UTFT myGLCD(CTE70CPLD,38,39,40,41), and neither option worked. All I got was a dead screen. I assume the screen needs to initialize after the code is loaded, so I would hit the reset button. I noticed when I hit the reset button on the Due, I got absolutely nothing. So I hit the reset button on an Uno to see what it would do, and the TX/RX lights both blinked.
  2. I tried the loopback test by jumping the gnd & reset and the RX to TX pins. Couldn’t communicate with the board at all when that was the case. Said couldn’t find board on COM8. Took off the jumpers and it could communicate with the board again.
  3. The 7" LCD screen actually has it’s own slot for an SD card, just like the TFT SD Shield. I tried the SD card in both the screen and the shield. It’s just a basic 1GB card. While it looked like the code loaded successfully, I’m not sure if anything was actually loaded to the flash memory? (Is flash memory actually on the Due board, or is it referring to the SD card?)
So I’m kind of stumped. Anyone have any ideas on what to try next?
