Arduino Due Rotary Encoder Keyboard
Hello,
I am trying to write a sketch to create an additional keyboard to pilot some softwares I am using with rotary encoders.
The software accepts keys shortcut so I just need arduino to send the same letter (or combination of letters) to the software in order to interact with it: basically, every time I turn the rotary encoder one way it should send the exact same signal.
I am using this sketch:
#include "Keyboard.h"
int encoderPin1 = 4;
int encoderPin2 = 5;
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
long lastencoderValue = 0;
int lastMSB = 0;
int lastLSB = 0;
  Serial.begin (9600);
  Keyboard.begin();
  pinMode(encoderPin1, INPUT_PULLUP);
  pinMode(encoderPin2, INPUT_PULLUP);
  attachInterrupt(0, updateEncoder, CHANGE);
  attachInterrupt(1, updateEncoder, CHANGE);
void loop(){
  Serial.println(encoderValue);
void updateEncoder(){
  int MSB = digitalRead(encoderPin1); //MSB = most significant bit
  int LSB = digitalRead(encoderPin2); //LSB = least significant bit
  int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
  int sum  = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
  if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) {
    // PRESS Q EVERY TIME TURNED
    Keyboard.write('Q');
    Keyboard.end();
  if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue --;
  lastEncoded = encoded; //store this value for next time
The problem I got is that, every turn, Arduino sends 'Q' twice.
I don't get why that happens...
Also, I have read to be careful using Keyboard.h as Arduino board might get stucked in that state.
So, everytime I use a function with "Keyboard.write()" shall it be followed by the function Keyboard.end()?
Sorry for the noob questions...
Is there a more convenient way to manage rotary encoders on Arduino DUE?
On Arduino UNO I was using "Encoder_Polling_V2.h" which worked like magic but it seems like it doesn't work on Arduino DUE.
Many many thanks as usual for your precious support!
My best,
Alessandro
PS: Eventually I should be able to read 43 Rotary Encoder plus some other buttons.
Could I use something like THIS to save pins with so many rotary encoders on Arduino DUE?
