Arduino Due RS485
I am using Arduino Due board
I used rs485 mode of USART1
I can transmit but for reception i want to use interrupt enable reception
But i cant?
Please reply if any
Hi rk_on_arduino,
If you need to read characters from the serial port from outside the main loop() function, then it's necessary to either set up a timer to poll the serial port at regular intervals, (which is somewhat inefficient, as you're calling both Serial and timer interrupts), or to comment out the USART's interrupt handler function in the Due's "variant.cpp" file, where it's located and copy it into your own sketch.
Currently the Due's "variant.cpp" file is located (at least on my PC) at:
C:\Users\Computer\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\variants\arduino_due_x\variant.cpp
In the "variant.cpp" file comment out the interrupt handler for the given USART:
void USART1_Handler(void)
  Serial2.IrqHandler();
Then copy this code into you own sketch outside the setup() and loop() functions.
The Serial2.IrqHandler() function simply reads and writes characters to and from the Due's Tx and Rx ring buffers. To keep things simple, it might be easier to leave the Serial2.IrqHandler() function intact and insert you own code that reads characters with the Serial2.read() function after it. This allows you to pull characters off the Rx ring buffer as they arrive.
This method is somewhat inefficient though, as it defeats the object of having the Rx ring buffer that's designed to hold incoming characters until you get round to reading them in the loop() function. However, it does avoid you having to implement your own means of storing transmitted or received characters in the handler function itself using the USART's registers.
Note that any Arduino updates to the Due's core files will overwrite any changes made to the "variant.cpp" file.
...or do not comment anything in variant.cpp, but add this before your setup :
void USART1_Handler(void) attribute((weak));
/Serial2.IrqHandler();/
// your code here
Hi ard_newbie,
// your code here
Thanks.
That's a much better solution. Avoids having to mess around with the "variant.cpp" file.
Thanks
MartinL & ard_newbie
Will try and reply you soon and also will upload my code.
My only purpose is Arduino due communication with PC using RS485
I am able to transmit data but i dont know how to read data when USART is operating in RS485 mode
Thanks
Following is my code it transmits data Rs485 but for receive i dont know how to receive
i.e. interrupt enable reception
pinMode(RTS, OUTPUT); //RTS for USART1=Serial2 set as output.
digitalWrite(RTS,LOW);
USART1->US_WPMR = 0x55534100; //Unlock the USART Mode register, just in case. (mine wasn’t locked).
USART1->US_MR |= (1u << 0); //Set USART1 mode to RS485.
PIOA->PIO_WPMR = 0x50494F00; //Unlock PIOA register, just in case. (mine wasn’t locked).
PIOA->PIO_ABSR |= (0u << 14); //Set PIOA14 to 0 => Choosing peripheral A = RTS for D23/PA14. (my whole port was already set to 0)
PIOA->PIO_PDR |= (1u << 14); //: Disables the PIO from controlling the corresponding pin (enables peripheral control of the pin).
MeterSerial.begin(9600); //SERIAL_8N1
Wire.begin();
digitalWrite(RTS,HIGH);
Serial.println(“Sending data”);
MeterSerial.println(“wating for char”);
while(1)
Still i cant receive data via RS485 only can transmit
I tried
// Before setup function
PIOB->PIO_SODR |= PIO_PA12;
if ((USART1->US_CSR & US_CSR_RXRDY) == US_CSR_RXRDY)
get_dat = USART1->US_RHR; ;
Serial.println(get_dat);
//In setup function
NVIC_EnableIRQ(USART1_IRQn); //enable UART i interrupt controlleren
// in loop function
__enable_irq();
// cant receive data
Hi rk_on_arduino,
Personally, if you haven't already, I'd check the physical system. Is the RTS line low when you receive data and is data coming out of the RS-485 transceiver?
Have you successfully tried testing the receiver with a simple sketch, one that doesn't override the USART1_Handler() function and just reads the incoming data with Serial2.read() in the loop()?
Please check my code
when
USART1->US_MR |= (1u << 0)|(1<<11);//rs485 mode of USART1
Then i can transmit only but not receive
and if i changed above to
USART1->US_MR |= (1u << 1)|(1<<11);//HARDWARE HANDSHAKING MODE OF USART1
Then i can receive but not transmit
USART1->US_WPMR = 0x55534100; //Unlock the USART Mode register, just in case. (mine wasn't locked).
 USART1->US_MR |= (1u << 0)|(1<<11);//|(1<<19); //Set USART1 mode to RS485.
  USART1->US_CR |= (0u << 4)|(1u << 5)|(1u<<6);
PIOA->PIO_WPMR = 0x50494F00;   //Unlock PIOA register, just in case. (mine wasn't locked).
Wire.begin();
 inputString.reserve(10);
int mydat = 0;
  Serial.println("Transmitter check");
  MeterSerial.println("wating for char");
  delay(10);
while(1)
counter++;
    if(counter==1000)
     if(MeterSerial.available()>0)
      mydat = MeterSerial.read();
     if(mydat!=0&&mydat!=-1)
      Serial.println(mydat,DEC);
      counter = 0;
if(mydat == 115) //decimal value of 's' when received then transmit to check transmitter
  mydat = 0;
  delay(100);
Hi rk_on_arduino,
In the datasheet (page 801) it states that in RS-485 mode the RTS line is controlled by (and is the inverse of) the TXEMPTY bit in the USART interrupt registers. So it shouldn't be necessary to select this using GPIO, but to do this you'll need to activate the RTS1 pin found on pin D23 (PA14).
To enable the RTS1 pin you'll need to switch it perhipheral A on port A (PIOA) with the lines:
REG_PIOA_ABSR &= ~PIO_ABSR_P14;   // Ensure that peripheral pin is switched to peripheral A
REG_PIOA_PDR |= PIO_PDR_P14;      // Disable the GPIO and switch to the peripheral
Hi MartinL thanks
With the following code i can transmit and receive via RS485
But i need interrupt enable reception.
How i can do that? Please check my code
MeterSerial.begin(9600,SERIAL_8N1);   //SERIAL_8N1
  USART1->US_CR |= US_CR_RSTRX | US_CR_RSTTX | US_CR_RXDIS | US_CR_TXDIS;
  USART1->US_MR |= 0X8C1;//USART1 IN RS485 mode
  USART1->US_CR |= US_CR_TXEN|US_CR_RXEN;  //Enable Transmitter and Receiver
 char mydat = 0;
while(1)
while(MeterSerial.available())
     if(mydat!=0)
      Serial.println(mydat);
      if(mydat == 's')  //check if char 's' received if yes then transmit for test
      delay(100);
digitalWrite(RTS,HIGH);   //for transmitter RTS HIGH
MeterSerial.flush();   //Wait till transmit all char
  delay(100);
  mydat = 0;
Now I am not getting that how to enable interrupt when receiving data
I have searched and study and found US_IER to enable interrupt for transmitter and receiver
But how to define interrupt function?
I am trying and if success then will upload the code
if any idea then reply
rk_on_arduino:
Please use the auto-format in the IDE before posting code. The indentation is there for a reason. It makes it much faster for a new person looking at your code to understand the blocks and loops.
It's like asking for someone to find a speck of dirt on the beach.
I tried the following NVIC interrupt but not working
void USART1_Handler()
 PIOA->PIO_SODR |= PIO_PA12;
  if ((USART1->US_CSR&US_CSR_RXRDY) == 1)
   stringComplete = true;
NVIC_DisableIRQ(USART1_IRQn);
NVIC_ClearPendingIRQ(USART1_IRQn);
NVIC_SetPriority(USART1_IRQn, 1);
__enable_irq();
 char mydat = 0;
while(1)
counter++;
if(stringComplete == true)
        stringComplete = false;
if(counter >=30000)counter = 0;
Hi rk_on_arduino,
Although you've set the USART1 to RS-485 mode, you could try testing the USART1_Handler() interrupt service routine, by adding the Serial2.IrqHandler() (or in your case MeterSerial) function then reading the characters using Serial2.read(). This picks the characters out of the Rx ring buffer as they arrive. It's slightly inefficient, as it sort of defeats the object of using the ring buffer, but be should enable you to test that everything's working OK before optimising your code further:
void USART1_Handler(void) __attribute__((weak));
  Serial2.IrqHandler();      // Store the incoming character in the Rx ring buffer
  byte c = Serial2.read();   // Pull the character off the Rx ring buffer
  // Your code here...
I tried as bellow but not working
 MeterSerial.IrqHanler();
 get_dat = Meter.Serial.read();
stringComplete == true;
__enable_irq();
 char mydat = 0;
while(1)
counter++;
Shouldn't the line:
read...
Hi MartinL
As my purpose to interrupt enable reception of RS485 was not to loose data
After study datasheet and googling finally what i got is
When we use Arduino dues USART in RS485 Mode then reception is already interrupt enabled
Only we have to read the receive buffer which is of 128 bytes.
This interrupt runs in background.
I tested it and is ok and my problem solved
Thanks for your support
