I have a arduino Due connected to MCP4922 DAC and I need to boost the signal coming from that output from 0-5V to 0-25V, having looked around is the LM358 module enough to do this, I am using a module due to not having a huge amount of experience with amplifiers.
If not will the LM258 operational amplifier meet those specs (i am open to building the circuit if i have too).
The LM358 will work up to 32V supply abs max - so OK at 25V.
That module isn't the thing to get though, since its decoupling capacitor voltage
is not known, it might fail.
Get a DIP LM358 and build the circuit yourself - you need a non-inverting amp
with a gain of +5.
Put 10k resistor between DAC output and +ve opamp input.
Put 10k resistor between -ve opamp input and GND.
Put 40k resistor (1k + 39k) between -ve opamp input and opamp output.
10uF 50+V decoupling cap on 25V opamp supply.
Looking around even more it looks like i need logic level Mofset,
https://www.sparkfun.com/products/10213 would this work for what i need it do? with a circuit shown below, (there is a motor in the picture, however wont be driving a motor will be going into an ECU)
Manewc:
Is it possible to boost my signal up to 25V using a 12V supply voltage? How do you work out the resistor and capacitor values (so i can give it a go).
Sorry about the picture didnt realise it was so big.
Thanks
manewc
No, I said this: "The LM358 will work up to 32V supply abs max - so OK at 25V."
You have to supply the amp at 25V, and even then it can't quite get the output up to
the +ve rail, you'll get to 23.5V perhaps. No way round this, you need the voltage.
I am little confused, now i understand the amplifier above (i have to supply 25V and to the amplifier and my signal would go from 5V to 23.5V)
Now as i understand it if u have a signal of 5V and u have external voltage supply of 12-14V being given to the amplifier it can go up to 24V with feedback loop? what kind of amplifier would do this if this is possible?
