Arduino Due & Softwareserial.h
hi all,
i need to convert this code for arduino due but the library (Softwareserial.h and EEPROM)can't be running for the clock at 84Mhz.
 Multi-drop RS485 device control demo.
 Devised and written by Nick Gammon.
 Date: 7 September 2015
 Version: 1.0
 Licence: Released for public use.
 For RS485_non_blocking library see: http://www.gammon.com.au/forum/?id=11428
 For JKISS32 see: http://forum.arduino.cc/index.php?topic=263849.0
#include <RS485_non_blocking.h>
#include <SoftwareSerial.h>
#include <EEPROM.h>
// the data we broadcast to each other device
struct
  byte address;
  byte switches [10];
  int  status;
  }  message;
const unsigned long BAUD_RATE = 9600;
const float TIME_PER_BYTE = 1.0 / (BAUD_RATE / 10.0);  // seconds per sending one byte
const unsigned long PACKET_LENGTH = ((sizeof (message) * 2) + 6); // 2 bytes per payload byte plus STX/ETC/CRC
const unsigned long PACKET_TIME =  TIME_PER_BYTE * PACKET_LENGTH * 1000000;  // microseconds
// software serial pins
const byte RX_PIN = 2;
const byte TX_PIN = 3;
// transmit enable
const byte XMIT_ENABLE_PIN = 4;
// debugging pins
const byte OK_PIN = 6;
const byte TIMEOUT_PIN = 7;
const byte SEND_PIN = 8;
const byte SEARCHING_PIN = 9;
const byte ERROR_PIN = 10;
// action pins (demo)
const byte LED_PIN = 13;
const byte SWITCH_PIN = A0;
// times in microseconds
const unsigned long TIME_BETWEEN_MESSAGES = 3000;
unsigned long noMessagesTimeout;
byte nextAddress;
unsigned long lastMessageTime;
unsigned long lastCommsTime;
unsigned long randomTime;
SoftwareSerial rs485 (RX_PIN, TX_PIN);  // receive pin, transmit pin
// what state we are in
enum {
   STATE_NO_DEVICES,
   STATE_RECENT_RESPONSE,
   STATE_TIMED_OUT,
} state;
// callbacks for the non-blocking RS485 library
size_t fWrite (const byte what)
  rs485.write (what);
int fAvailable ()
  return rs485.available ();
int fRead ()
  lastCommsTime = micros ();
  return rs485.read ();
// RS485 library instance
RS485 myChannel (fRead, fAvailable, fWrite, 20);
// from EEPROM
byte myAddress;        // who we are
byte numberOfDevices;  // maximum devices on the bus
// Initial seed for JKISS32
static unsigned long x = 123456789,
                     y = 234567891,
                     z = 345678912,
                     w = 456789123,
                     c = 0;
// Simple Random Number Generator
unsigned long JKISS32 ()
  long t;
  y ^= y << 5;
  y ^= y >> 7;
  y ^= y << 22;
  t = z + w + c;
  z = w;
  c = t < 0;
  w = t & 2147483647;
  x += 1411392427;
  return x + y + w;
  }  // end of JKISS32
void Seed_JKISS32 (const unsigned long newseed)
  if (newseed != 0)
    x = 123456789;
    y = newseed;
    z = 345678912;
    w = 456789123;
    c = 0;
  }  // end of Seed_JKISS32
void setup ()
  // debugging prints
  Serial.begin (115200);
  // software serial for talking to other devices
  rs485.begin (BAUD_RATE);
  // initialize the RS485 library
  myChannel.begin ();
  // debugging prints
  Serial.println ();
  Serial.println (F("Commencing"));
  myAddress = EEPROM.read (0);
  Serial.print (F("My address is "));
  Serial.println (int (myAddress));
  numberOfDevices = EEPROM.read (1);
  Serial.print (F("Max address is "));
  Serial.println (int (numberOfDevices));
  if (myAddress >= numberOfDevices)
    Serial.print (F("** WARNING ** - device number is out of range, will not be detected."));
  Serial.print (F("Packet length = "));
  Serial.print (PACKET_LENGTH);
  Serial.println (F(" bytes."));
  Serial.print (F("Packet time = "));
  Serial.print (PACKET_TIME);
  Serial.println (F(" microseconds."));
  // calculate how long to assume nothing is responding
  noMessagesTimeout = (PACKET_TIME + TIME_BETWEEN_MESSAGES) * numberOfDevices * 2;
  Serial.print (F("Timeout for no messages = "));
  Serial.print (noMessagesTimeout);
  // set up various pins
  pinMode (XMIT_ENABLE_PIN, OUTPUT);
  // demo action pins
  pinMode (SWITCH_PIN, INPUT_PULLUP);
  pinMode (LED_PIN, OUTPUT);
  // debugging pins
  pinMode (OK_PIN, OUTPUT);
  pinMode (TIMEOUT_PIN, OUTPUT);
  pinMode (SEND_PIN, OUTPUT);
  pinMode (SEARCHING_PIN, OUTPUT);
  pinMode (ERROR_PIN, OUTPUT);
  // seed the PRNG
  Seed_JKISS32 (myAddress + 1000);
  state = STATE_NO_DEVICES;
  nextAddress = 0;
  randomTime = JKISS32 () % 500000;  // microseconds
  }  // end of setup
// set the next expected address, wrap around at the maximum
void setNextAddress (const byte current)
  nextAddress = current;
  if (nextAddress >= numberOfDevices)
    nextAddress = 0;
  }  // end of setNextAddress
// Here to process an incoming message
void processMessage ()
  // we cannot receive a message from ourself
  // someone must have given two devices the same address
  if (message.address == myAddress)
    digitalWrite (ERROR_PIN, HIGH);
    while (true)
      { }  // give up
    }  // can't receive our address
  digitalWrite (OK_PIN, HIGH);
  // handle the incoming message, depending on who it is from and the data in it
  // make our LED match the switch of the previous device in sequence
  if (message.address == (myAddress - 1))
    digitalWrite (LED_PIN, message.switches [0]);
  digitalWrite (OK_PIN, LOW);
  } // end of processMessage
// Here to send our own message
void sendMessage ()
  digitalWrite (SEND_PIN, HIGH);
  memset (&message, 0, sizeof message);
  message.address = myAddress;
  // fill in other stuff here (eg. switch positions, analog reads, etc.)
  message.switches [0] = digitalRead (SWITCH_PIN);
  // now send it
  digitalWrite (XMIT_ENABLE_PIN, HIGH);  // enable sending
  myChannel.sendMsg ((byte *) &message, sizeof message);
  digitalWrite (XMIT_ENABLE_PIN, LOW);  // disable sending
  setNextAddress (myAddress + 1);
  digitalWrite (SEND_PIN, LOW);
  lastCommsTime = micros ();   // we count our own send as activity
  }  // end of sendMessage
void loop ()
  // incoming message?
  if (myChannel.update ())
    int len = myChannel.getLength ();
    if (len > sizeof message)
      len = sizeof message;
    memcpy (&message, myChannel.getData (), len);
    lastMessageTime = micros ();
    setNextAddress (message.address + 1);
    processMessage ();
    state = STATE_RECENT_RESPONSE;
    }  // end of message completely received
  // switch states if too long a gap between messages
  if  (micros () - lastMessageTime > noMessagesTimeout)
  else if  (micros () - lastCommsTime > PACKET_TIME)
    state = STATE_TIMED_OUT;
  switch (state)
    // nothing heard for a long time? We'll take over then
    case STATE_NO_DEVICES:
      if (micros () - lastCommsTime >= (noMessagesTimeout + randomTime))
        Serial.println (F("No devices."));
        digitalWrite (SEARCHING_PIN, HIGH);
        sendMessage ();
        digitalWrite (SEARCHING_PIN, LOW);
    // we heard from another device recently
    // if it is our turn, respond
    case STATE_RECENT_RESPONSE:
      // we allow a small gap, and if it is our turn, we send our message
      if (micros () - lastCommsTime >= TIME_BETWEEN_MESSAGES && myAddress == nextAddress)
        sendMessage ();
    // a device did not respond in its slot time, move onto the next one
    case STATE_TIMED_OUT:
      digitalWrite (TIMEOUT_PIN, HIGH);
      setNextAddress (nextAddress + 1);
      lastCommsTime += PACKET_TIME;
      digitalWrite (TIMEOUT_PIN, LOW);
      state = STATE_RECENT_RESPONSE;  // pretend we got the missing response
    }  // end of switch on state
  }  // end of loop
For EEPROM maybe solved directly assigning values to variables required.
someone would know help me?
thank you
Get rid of software serial and use one of the hardware serials instead. A look at the datasheet would have been a good idea.
Mark
the hardware serial is good for Arduino nano, i must connect more of this to arduino due.
i need use this?
https://github.com/arduino/Arduino/blob/master/hardware/arduino/avr/cores/arduino/HardwareSerial.h
and
https://github.com/arduino/Arduino/blob/master/hardware/arduino/avr/cores/arduino/HardwareSerial.cpp
however for me it is too complicated, I think buy other Arduino Nano, so I have to do only a digital extension. I can not expect someone to do me a complete code for what it takes to me.
Gammon is already much that he published his tutorial on communication Rs485
up
You can't use that with the DUE as it#s not a AVR.
Serial,Serial1 etc are hardware serial and the Due has all 4. Just use 1! and get rid of software Serial which cannot work on the Due as it's designed for the AVR chips.
Mark
ok, I buy other Arduino Nano is the fastest solution. I am going to use the Arduino Due other projects
