I would like to connect two Arduino Due's using SPI with the goal being the slave using the analog output (0.55 volts to 2.75 volts). Is this possible?
Yes, or you could use I2C or Serial or home brew some thing.
Mark
I guess my next question is what code would I need to be able to bridge between the master and slave while being able to have the slave board to run the analog output
