i have a problem with my DUE. My Hardware are the Ethernet Shield 2: Link and the ITDB02-5.0 DisplayLink.
Both are using the SPI Bus, the CS-Pin for the Display is 7 and for the shiel is 10.
The most of my sketch works, including the SPI communication to the Ethernet Shield 2.
But the thing that isn't working, is loading pictures from the SD Card Socket on the Display.
It does only load thw Pictures when i remove MISO from the Ethernet shield.
Does anybody have an idea why it isn't working?
// 1.Einbinden der Bibliotek
#include <UTFT.h> //Bildschirm
#include<URTouch.h> //Touchscreen
#include <SPI.h> //SPI Kommunikation zum EthernetBoard
#include "SdFat.h" //Speicherkarte zusatz
#include <UTFT_SdRaw.h> //Speicherkarte
#include <Wire.h> //I2C
#include <Ethernet2.h> //EThernet
#include <EthernetUdp2.h> //UDP für Shield 2
//2.Laden der Schriftarten
extern uint8_t SmallFont[]; // Größe in x und y = 8x12
extern uint8_t BigFont[]; //Größe in x und y = 16x16
extern uint8_t GroteskBold24x48[]; //Muss sich im Ordner befinden Größe in x und y = 24x48
//Anzeige I/Os Konfigurieren
UTFT myGLCD(ITDB50,43,45,47,49);
URTouch myTouch( 38, 40, 42, 46, 48);
//SD-Karte konfigurieren
UTFT_SdRaw myFiles(&myGLCD);
#define SD_CHIP_SELECT 7 // SD Auswahlpin Chipselect
SdFat sd;
//Temperatursensor Adresse und Prozessorchip setzen
#define Addr 0x27
#define AT91SAM3X8E
//Variablen deklarieren
boolean Schleife_2 = true; //Schleife
byte stunden_1 =0;
byte minuten_1 =0;
byte sekunden_1 =0;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
char Feucht[9];
char Warm[9];
char lol []={"00:00:00"};
char liste[60] ={ 0x00, 0x01, 0x02, 0x03, 0x04,0x05,0x06,0x07,0x08,0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59};
//char Zeiten [90]={0,1,2,3,4,5,6,7,8,9,0,0,0,0,0,0,10,11,12,13,14,15,16,17,18,19,0,0,0,0,0,0,20,21,22,23,24,25,26,27,28,29,0,0,0,0,0,0,30,31,32,33,34,35,36,37,38,39,0,0,0,0,0,0,40,41,42,43,44,45,46,47,48,49,0,0,0,0,0,0,50,51,52,53,54,55,56,57,58,59};
float a=0;
float b=0;
float wert=0;
float feuchte =0;
float cTemp =0;
int s=0;
int i=0;
int x,y;
int Paket; //Variable for the incoming string
int Stunden=0;
int Minuten=0;
int Sekunden=0;
int nummern_1 = 0;
int nummern_2 = 0;
int nummern_3 = 0;
int nummern_4 = 0;
int nummern_5 = 0;
int nummern_6 = 0;
int nummern_7 = 0;
int nummern_8 = 0;
int sichern_1 = 0;
int sichern_2 = 0;
int sichern_3 = 0;
int sichern_4 = 0;
int sichern_5 = 0;
int sichern_6 = 0;
int sichern_7 = 0;
int sichern_8 = 0;
String nulll = String("0");
String stringh;
String stringmin;
String stringsek;
String doppel = String(":");
String stringges;
unsigned long lastReadingTime = 0;
unsigned long lastmillis = 0;
//Einstellung MAC adresse //Settings MAC addresse
byte mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0x22, 0xEE};
// IP Einsellungen //Ip settings
IPAddress ip(nummern_1, nummern_2, nummern_3, nummern_4);
IPAddress gateway(nummern_5, nummern_6, nummern_7, nummern_8);
EthernetUDP Udp;
#define UDP_CHIP_SELECT 10
if(s==0)
Paket = Udp.parsePacket(); //Empfange packet //receive the Packet
if(Paket) {
Serial.print("Received packet of size ");
Serial.println(Paket);
Serial.print("From ");
IPAddress remote = Udp.remoteIP();
for (int i = 0; i < 4; i++)
Serial.print(remote[i], DEC);
if (i < 3)
Serial.print(".");
Serial.print(", port ");
Serial.println(Udp.remotePort());
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
Serial.println("Contents:");
Serial.println(packetBuffer);
Udp.beginPacket(Udp.remoteIP(), 8888);
Udp.write(Feucht);
Udp.endPacket();
Serial.println("Feuchte in %");
Serial.println(Feucht);
delay(3);
Udp.write(Warm);
Udp.endPacket();
delay(3);
Udp.print(stringges);
Udp.endPacket();
Serial.println("Wärm in C");
Serial.println(Warm);
Serial.println("Orginal Werte:");
Serial.println(feuchte);
Serial.println(cTemp);
Serial.println("Uhrzeit:");
Serial.println(stringges);
for(int c=0;c<UDP_TX_PACKET_MAX_SIZE;c++)
{ packetBuffer[c] = 0; }
if (millis() - lastReadingTime > 860)
Uhr(); //lade Uhrzeit
analog(); //lade Luftdruck
tmp_lesen (); //lade Feuchtigkeit und Temperatur
lastReadingTime = millis();
if(s==1) //Beende Loop2
s=0; //gehe ins Normal Programm
screen1(); //lade Bildschirm1
attachInterrupt(8, screen2, FALLING); //erlaube den Bildscirminterrupt
if(s==2)
{loop2();} // Fuehre das Einstellungfenster Aus
if(s==3)
{Uhrstellen();} // Fuehre Programm Uhrzeitstellen aus
if(s==4)
{IPstellen();} // Fuehre Programm IPstellen aus
if(s==5)
{Router();} // Fuehre Programm Routerstellen aus
if(s>5||s<0)
{s=1;} //verhindere das s im undefinierten bereich ist
