arduino due tft
You know if you need to use a shield to connect a 4.3-inch TFT display to an Arduino due
if you can tell me a link where to buy it maybe together with the display of course I also have to use the touch
hello giggi
Hi Giggi,
You don't NEED a shield to connect to the DUE but it makes life a whole lot easier if you have one.
I would recommend buying from Coldtears electronics as you will have no problems with items from them.
Display here:-
Shield here :-
http://www.ebay.com/itm/TFT-SD-Shield-Arduino-DUE-TFT-LCD-Module-SD-Card-Adapter-2-8-3-2-inch-Mega-/121057447668?hash=item1c2f960ef4
However, there is a cheaper clone supplier selling similar items which most people buy, but then have problems of one sort or another!! Be warned!!
Shield and display here :-
http://www.sainsmart.com/sainsmart-4-3-4-3-inch-tft-lcd-screen-sd-card-slot-tft-shield-for-arduino-due.html
Regards,
Graham
what makes me easier if you use the shield??
because I live in Italy and I need them before the end of the components month
Giggi
If you have a shield, this plugs into the Due, the TFT plugs into the shield, simple! If you don't have a shield, you have approximately 40 wires to connect....... and then figure out where you went wrong and why it is not working properly....
Regards,
Graham
Can you tell me a site where to buy the display with a fast delivery to Italy
Giggi
I am sorry, I can’t. Typically from Hong Kong takes about 2 weeks to UK.
Regards,
Graham
thanks for the help
you give me some examples of where you use both the touch that the display at the same time I would be grateful
Giggi
Maybe a Gameduino 2:
http://www.robot-domestici.it/joomla/component/virtuemart/prodotti-al-prezzo-di-costo/seeedstudio/rgb/gameduino-2
Runs ok directly on Due
Or with an interface
