I currently want to make a project with NB-IoT and an ePaper display. I am using a Good Display 2.9'', similar to this one. Is there some sort of adapter from an Arduino DUE to the connector of the display?
As you can see on the picture attached, the NB-IoT module needs quite a lot of space and covers the 2x3 "pin-layout" with the name SPI (not sure if I need this).
You need a connection board to connect these SPI e-paper displays to any processor. It needs to have the booster circuit to generate the panel driving voltages.
Note that the commonly used Arduino libraries for these e-paper displays use HW SPI, which is not accessible with your configuration, as HW SPI is on the 6pin ICSP header on Arduino Due.
So thank you both for your answers. As you know, the NB-IoT module needs these "side" pins, just like the board you sent me. Don't they bother each other?
