Arduino Due - unable to upload program via bluetooth
Hello everyone,
this forum helped me a lot with solving my problems, but right now i have a new problem and i can´t find a solution. I´m trying to use bluetooth to connect my arduino due to a computer (windows 7). The bluetooth device is the HC 05. I connected it to TX0 and RX0 pins on the arduino and i´m using a circuit (which is provided in the data sheet) with two leds, which show in which state the bluetooth device is and if it has a connection. The problem i have is: i can change the settings like the name of the device and the password, i can upload my code via usb to the arduino and then connect to the arduino via bluetooth. Then the serial monitor will show the data sent from the arduino. I can send commands and the arduino receives it. But as soon as i try to upload code via bluetooth the software says that there was no device found at the port. Does anyone know why this happens?
I hope you can help me!
Kind regards, Slevin
Why do you assume that you should be able to upload code via the bluetooth device?
I used this Tutorial: http://makezine.com/projects/diy-arduino-bluetooth-programming-shield/ Do you have an idea what i am doing wrong?
Does your Arduino look like the one in that picture?
No.
You can upload with Apploader app from iPad or iPhone over BLE: http://www.apploader.info/p/introduction.html
Hi Slevin,
I presently want to send analog sensor data from my DUE to my computer via bluetooth. I already have a working code to send data via USB and print it to serial monitor, but can't figure out how to do it with my HC-06 module.
Can you tell me how you managed to do it? I dont want to program the DUE via bluetooth, just send data from it to the computer.
Thanks!
