Arduino Due using Eclipse Luna Ubuntu 14.04
Anyone manage to get Arduino Due working using the eclipse Luna c/c++ dev on Ubuntu 14.04? Mine cant seem to work plus I need to use the Arduino IDE Serial example code but via the eclipse platform.
Thanks.
CuriousPanda: plus I need to use the Arduino IDE Serial example code but via the eclipse platform.
The Arduino won't work any better and you will have spent a lot of time trying not to use the Arduino IDE :)
What's wrong with simple?
...R
Yeah, I need the serial library to integrate with other codes and I find that it is not very convenient to use Arduino ide as I will need the project to reference it to many other personalised libraries too.
Anyone knows what are the header files behind the Arduino Serial Event example? :~
n also when I try to compile, i get these errors in wire.cpp of the Arduino SAM libraries.
In function 'void Wire_Init()': 'WIRE_ISR_ID' was not declared in this scope In function 'void Wire1_Init()': 'WIRE1_ISR_ID' was not declared in this scope
what should i do? :~ :~
