Arduino due UTFT Wprogram.h missing
Hi guys,
I tried to compile UTFT demo for 32*240 UTFT lcd Display but I´ve got this error:
Arduino: 1.6.6 (Windows 7), Board: "Arduino Due (Programming Port)"
Warning: platform.txt from core 'Arduino ARM (32-bits) Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
In file included from C:\Users\Pazdo\Documents\Arduino\libraries\UTFT\examples\chipKit\UTFT_Demo_320x240\UTFT_Demo_320x240.pde:13:0:
C:\Users\Pazdo\Documents\Arduino\libraries\UTFT/UTFT.h:109:23: fatal error: WProgram.h: No such file or directory
  #include "WProgram.h"
compilation terminated.
exit status 1
Error compiling.
  enabled in File > Preferences.
I tried compile in Uno mode and it works good I don´t know what to do can you help me ?
The use of "Wprogram.h" has been obsolete since Arduino 1.0. You should look for a more recent library for your UTFT display. Try selecting Sketch->Include Library->Manage Libraries... and under Type select "Updatable" to see if there is a known update for your libraries.
