I'm newbie about the Arduino Due.
I'm want to use the interrupt when the program deadlock. Now I can enable the watchdog timer but how to use the interrupt function?
uint32_t status = (RSTC->RSTC_SR & RSTC_SR_RSTTYP_Msk) >> 8; // Get status from the last Reset
Serial.print("RSTTYP = 0b"); Serial.println(status, BIN); // Should be 0b010 after first watchdog reset
This example sketch uses watchdog interrupt Handler but do not reset the uc:
#define WDT_KEY (0xA5)
void watchdogSetup(void) {}
// Enable watchdog.
WDT->WDT_MR = WDT_MR_WDD(0xFFF) |
WDT_MR_WDFIEN | // Triggers an interrupt or WDT_MR_WDRSTEN to trigger a Reset
WDT_MR_WDV(256 * 2); // Watchdog triggers a reset or an interrupt after 2 seconds if underflow
// 2 seconds equal 84000000 * 2 = 168000000 clock cycles
/* Slow clock is running at 32.768 kHz
watchdog frequency is therefore 32768 / 128 = 256 Hz
WDV holds the periode in 256 th of seconds */
NVIC_EnableIRQ(WDT_IRQn);
Serial.begin(250000);
uint32_t status = (RSTC->RSTC_SR & RSTC_SR_RSTTYP_Msk) >> RSTC_SR_RSTTYP_Pos /*8*/; // Get status from the last Reset
//Restart watchdog
WDT->WDT_CR = WDT_CR_KEY(WDT_KEY)
| WDT_CR_WDRSTT;
Serial.println("Enter the main loop : Restart watchdog");
GPBR->SYS_GPBR[0] += 1;
Serial.print("GPBR = "); Serial.println(GPBR->SYS_GPBR[0]);
while (true)
Serial.println("the software becomes trapped in a deadlock !");
/* If the software becomes trapped in a deadlock,
watchdog triggers a reset or an interrupt. if there is a reset, the software restarts with stored values
in General Purpose Back up Registers*/
void WDT_Handler(void)
WDT->WDT_SR; // Clear status register
printf("help! in WDT\n");
