Arduino Duemilanove and Wiring
Good day
Does the wiring language work on the arduino duemilanove board? Can it be made to work? Is it good out of the box or does the bootloader need replacing?
I'd appreciate any other information you could provide.
Thank you for your time
The wiring language is very similar but does not work out of the box on the Arduino boards.
It might help if we knew why you wanted to do this.
The arduino language is based on wiring language. So why would you need to use wiring. Should be an easy integration!
