Arduino dueSAM3X PDC/DMA
Hi Everyone,
i am new to this community and new to Arduino Due as well . I am trying to implement an IIR filter using the SAM3X board for real-time . Based on some code from ard_newbie i was able to drive the ADC and DAC controller to read analog values and output them as they are. however i would like do some filtering before sending them to the DAC and i save these sampled data to an array so i can perform a moving average filter. It seems like the data are transfer from register to register without being assigned to any variables. I hope i explained my issue well.
Any help is greatly appreciated.
/*  44.1 KHz ADC conversions of A0 , idem for A1, triggered by Timer Counter 0 channel 1 TIOA1           */
/*  44.1 KHz DAC output on DAC0, idem for DAC1, triggered by Timer Counter 0 channel 2 TIOA2             */
volatile uint8_t bufn, Oldbufn, bufn_dac;
const uint16_t bufsize = 128;
const uint8_t bufnumber = 4;
const uint8_t _bufnumber = bufnumber - 1;
volatile uint16_t buf[bufnumber][bufsize];
  pinMode(LED_BUILTIN, OUTPUT);  // For ADC debugging
  pinMode(12, OUTPUT);           // For DACC debugging
  adc_setup();
  dac_setup();
  tc_adc_setup();
  tc_dac_setup();
/*************  Configure adc_setup function  *******************/
void adc_setup() {
  PMC->PMC_PCER1 |= PMC_PCER1_PID37;                    // ADC power ON
  ADC->ADC_CR = ADC_CR_SWRST;                           // Reset ADC
  ADC->ADC_MR |=  ADC_MR_TRGEN_EN                       // Hardware trigger select
                  | ADC_MR_TRGSEL_ADC_TRIG2             // Trigger by TIOA1
                  | ADC_MR_PRESCAL(1);
  // ADC->ADC_ACR = ADC_ACR_IBCTL(0b01);                 // For frequencies > 500 KHz
  ADC->ADC_IDR = ~ADC_IDR_ENDRX;
  ADC->ADC_IER = ADC_IER_ENDRX;                         // End Of Conversion interrupt enable for channel 7
  //NVIC_SetPriority(ADC_IRQn, 0xFF);
  NVIC_EnableIRQ(ADC_IRQn);                             // Enable ADC interrupt
  ADC->ADC_CHER = ADC_CHER_CH6 | ADC_CHER_CH7;          // Enable Channels 7 = A0 and 6 = A1; Trigger frequency is multiplied by 2
                                                        // The sampling frequency for 1 channel times the number of channels !!
  /*********  PDC/DMA  buffer filling sequence **********/
  ADC->ADC_RPR = (uint32_t)buf[2];                      // DMA buffer - First one will be buf[1]
  ADC->ADC_RCR = bufsize;
  ADC->ADC_RNPR = (uint32_t)buf[3];                     // next DMA buffer
  ADC->ADC_RNCR = bufsize;
  bufn = 3;
  ADC->ADC_PTCR |= ADC_PTCR_RXTEN;                      // Enable PDC Receiver channel request
  //ADC->ADC_CR = ADC_CR_START;
/*********  Call back function for ADC PDC/DMA **************/
void ADC_Handler () {
  //if ( ADC->ADC_ISR & ADC_ISR_ENDRX) {               // Useless because the only one
  Oldbufn = bufn;
  bufn = (bufn + 1) & _bufnumber;
  ADC->ADC_RNPR = (uint32_t)buf[bufn];
  boolean chsel;
  for (uint8_t i = 0; i < bufsize; i++) {
    buf[Oldbufn][i] |= chsel << 12;                    // Select alternatively DAC0 and DAC1
    chsel = !chsel;
  // Todo : digital filtering before DAC output
  // For debugging only
  static uint32_t Count;
  if (Count++ == 689) { //84000000/8/238/2/128  = ~689
    Count = 0;
    PIOB->PIO_ODSR ^= PIO_ODSR_P27;  // Toggle LED_BUILTIN every 1 Hz
void dac_setup ()
  PMC->PMC_PCER1 = PMC_PCER1_PID38;                   // DACC power ON
  DACC->DACC_CR = DACC_CR_SWRST ;                     // Reset DACC
  DACC->DACC_MR = DACC_MR_TRGEN_EN                    // Hardware trigger select
                  | DACC_MR_TRGSEL(0b011)             // Trigger by TIOA2
                  | DACC_MR_TAG_EN                    // Output on DAC0 and DAC1
                  | DACC_MR_WORD_HALF
                  | DACC_MR_REFRESH (1)
                  | DACC_MR_STARTUP_8
                  | DACC_MR_MAXS;
  DACC->DACC_ACR = DACC_ACR_IBCTLCH0(0b11) //0b10
                   | DACC_ACR_IBCTLCH1(0b11) // 0b10
                   | DACC_ACR_IBCTLDACCORE(0b01);
  DACC->DACC_IDR = ~DACC_IDR_ENDTX;
  DACC->DACC_IER = DACC_IER_ENDTX;                    // TXBUFE works too !!!
  //NVIC_SetPriority(DACC_IRQn, 0xFF);
  NVIC_EnableIRQ(DACC_IRQn);
  DACC->DACC_CHER = DACC_CHER_CH0 | DACC_CHER_CH1;    // enable channels 1 = DAC1 and 0 = DAC0
  /*************   configure PDC/DMA  for DAC *******************/
  DACC->DACC_TPR  = (uint32_t)buf[0];                 // DMA buffer
  DACC->DACC_TCR  = bufsize;
  DACC->DACC_TNPR = (uint32_t)buf[1];                 // next DMA buffer
  DACC->DACC_TNCR =  bufsize;
  bufn_dac = 1;
  DACC->DACC_PTCR = DACC_PTCR_TXTEN;                  // Enable PDC Transmit channel request
/*********  Call back function for DAC PDC/DMA **************/
void DACC_Handler() {   // DACC_ISR_HANDLER()         // move Sinus/PDC/DMA pointers to next buffer
  //if ( DACC->DACC_ISR & DACC_ISR_ENDTX) {           // Useless because the only one
  bufn_dac = (bufn_dac + 1) & _bufnumber;
  DACC->DACC_TNPR = (uint32_t)buf[bufn_dac];
  if (Count++ == 689) { //84000000/8/119/128 = ~689
    Count = 0;
    PIOD->PIO_ODSR ^= PIO_ODSR_P8;  // Toggle LED_BUILTIN every 1 Hz
/*******  Timer Counter 0 Channel 1 to generate PWM pulses thru TIOA1  for ADC ********/
void tc_adc_setup() {
  PMC->PMC_PCER0 |= PMC_PCER0_PID28;                      // TC1 power ON : Timer Counter 0 channel 1 IS TC1
  TC0->TC_CHANNEL[1].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK2  // MCK/8, clk on rising edge
                              | TC_CMR_WAVE               // Waveform mode
                              | TC_CMR_WAVSEL_UP_RC       // UP mode with automatic trigger on RC Compare
                              | TC_CMR_ACPA_CLEAR         // Clear TIOA1 on RA compare match
                              | TC_CMR_ACPC_SET;          // Set TIOA1 on RC compare match
  TC0->TC_CHANNEL[1].TC_RC = 238;  //<*********************  Frequency = (Mck/8)/TC_RC  Hz = 44.1 Hz
  TC0->TC_CHANNEL[1].TC_RA = 40;  //<********************   Any Duty cycle in between 1 and TC_RC
  TC0->TC_CHANNEL[1].TC_CCR = TC_CCR_CLKEN;               // TC1 enable
/*******  Timer Counter 0 Channel 2 to generate PWM pulses thru TIOA2  for DACC ********/
void tc_dac_setup() {
  PMC->PMC_PCER0 |= PMC_PCER0_PID29;                      // TC2 power ON : Timer Counter 0 channel 2 IS TC2
  TC0->TC_CHANNEL[2].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK2  // MCK/8, clk on rising edge
                              | TC_CMR_ACPA_CLEAR         // Clear TIOA2 on RA compare match
                              | TC_CMR_ACPC_SET;          // Set TIOA2 on RC compare match
  TC0->TC_CHANNEL[2].TC_RC = 119;  //<*********************  Frequency = (Mck/8)/TC_RC  Hz = 88.2 Hz
  TC0->TC_CHANNEL[2].TC_RA = 20;  //<********************   Any Duty cycle in between 1 and TC_RC
  TC0->TC_CHANNEL[2].TC_CCR = TC_CCR_CLKEN;               // TC2 enable
  TC0->TC_BCR = TC_BCR_SYNC;                              // Synchro TC1 and TC2
