Arduino e Processing ... non va !
stavo testando i programmi di esempio di processing per comunicare con Arduino
in particolare, ho caricato l'esempio di Processing : Simple Write
se ho capito bene, dovrebbe accedermi un led se passo sopra all'immagine quadrata che mi crea a video
ho caricato il programma in Arduino e avviato quello di Processing ... ma nulla da fare !
l'esempio dice : // I know that the first port in the serial list on my mac * // is always my FTDI adaptor, so I open Serial.list()[0].* * // On Windows machines, this generally opens COM1.* * // Open whatever port is the one you're using.* * String portName = Serial.list()[0];*
e a video compare :
Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 [0] "COM1" [1] "COM3"
ma devo settare diversamente la seriale visto che ho Windows ?
sono un po' in confusione ... forse sto partendo troppo forte ! ::)
ciao e grazie
Inserisco i due listati :
Processing :
 * Simple Write.
 * Check if the mouse is over a rectangle and writes the status to the serial port.
 * This example works with the Wiring / Arduino program that follows below.
import processing.serial.*;
Serial myPort;  // Create object from Serial class
int val;        // Data received from the serial port
  println(Serial.list());
  size(200, 200);
  myPort = new Serial(this, portName, 9600);
void draw() {
  background(255);
  if (mouseOverRect() == true) {  // If mouse is over square,
    fill(204);                    // change color and
    myPort.write('H');              // send an H to indicate mouse is over square
  else {                        // If mouse is not over square,
    fill(0);                      // change color and
    myPort.write('L');              // send an L otherwise
  rect(50, 50, 100, 100);         // Draw a square
boolean mouseOverRect() { // Test if mouse is over square
  return ((mouseX >= 50) && (mouseX <= 150) && (mouseY >= 50) && (mouseY <= 150));
E Arduino :
  // Wiring/Arduino code:
 // Read data from the serial and turn ON or OFF a light depending on the value
 char val; // Data received from the serial port
 int ledPin = 4; // Set the pin to digital I/O 4
 pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
 Serial.begin(9600); // Start serial communication at 9600 bps
 if (Serial.available()) { // If data is available to read,
 val = Serial.read(); // read it and store it in val
 if (val == 'H') { // If H was received
 digitalWrite(ledPin, HIGH); // turn the LED on
 digitalWrite(ledPin, LOW); // Otherwise turn it OFF
 delay(100); // Wait 100 milliseconds for next reading
Controlla la porta in uso nell'ide arduino, tools -> Serial Port e scrivi la stessa cosa direttamente nel codice in Processing, tra doppi apici. Ad esempio io ho settato (sul mac):
String portname = "/dev/tty.usbserial-A6006jY0";
sul PC potrebbe essere qualcosa come:
String portname = "COM2";
Grazie ! giusto ieri ho risolto mettendo
String portName = Serial.list()[1];
dopo il tuo mex ho provato con COM3 e funziona anche così ;)
ciao !
