good morning,
I am making a syringe heater. I have the screen (gen4-ULCD-32DT-AR) connected with Arduino. A thermocouple and a 12V heating element is connected to the Arduino. I power the Arduino with an external 12V jack. initially the screen works, after a few minutes it starts to reset continuously saying "mounting". I cannot understand the problem. I would like to heat the heating element by giving commands via the screen.
Thanks !
The code:
#include <genieArduino.h> //interact between 4D touch pad and arduino, https://github.com/4dsystems/ViSi-Genie-Arduino-Library
#include <PID_v1.h> //PID control heater, https://github.com/br3ttb/Arduino-PID-Library/
#include <SPI.h>
#include "Adafruit_MAX31855.h"
#define MAXSS 10
Adafruit_MAX31855 thermocouple(MAXSS);
//Keyboard variables
char keyvalue[10]; // array to hold keyboard values
char keyvalue2[10]; // array to hold keyboard values
int temp; //temporary event variable from keyboard
int counter = 0;
int counter2 = 0;
//Temperature variables
bool RunHeater = 0;
float TempSetPoint = 37; //setpoint temperature (default 37);
int tempPin = 0; //the analog pin the TMP36's Voltage-out pin is connected to
int heaterPin = A5; //the analog pin the TIP 120 transistor is connected to
int x;
unsigned int tempReading = 0;
unsigned long tempReadingTotal = 0;
double Setpoint, Input, Output, temperatureC;
//Define the Tuning Parameters
double Kp = 150, Ki = 1, Kd = 0;
//Specify the links and tuning parameters
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
Genie genie;
#define RESETLINE 4 // Change this if you are not using an Arduino Adaptor Shield Version 2 (see code below)
Serial.begin(200000); // Serial0 @ 200000 (200K) Baud
genie.Begin(Serial); // Use Serial0 for talking to the Genie Library, and to the 4D Systems display
genie.AttachEventHandler(myGenieEventHandler); // Attach the user function Event Handler for processing events
// Reset the Display (change D4 to D2 if you have original 4D Arduino Adaptor)
// THIS IS IMPORTANT AND CAN PREVENT OUT OF SYNC ISSUES, SLOW SPEED RESPONSE ETC
// If NOT using a 4D Arduino Adaptor, digitalWrites must be reversed as Display Reset is Active Low, and
// the 4D Arduino Adaptors invert this signal so must be Active High.
pinMode(RESETLINE, OUTPUT); // Set D4 on Arduino to Output (4D Arduino Adaptor V2 - Display Reset)
digitalWrite(RESETLINE, 1); // Reset the Display via D4
delay(100);
digitalWrite(RESETLINE, 0); // unReset the Display via D4
delay (3500); //let the display start up after the reset (This is important)
// Set the brightness/Contrast of the Display - (Not needed but illustrates how)
// Most Displays, 1 = Display ON, 0 = Display OFF. See below for exceptions and for DIABLO16 displays.
// For uLCD-43, uLCD-220RD, uLCD-70DT, and uLCD-35DT, use 0-15 for Brightness Control, where 0 = Display OFF, though to 15 = Max Brightness ON.
genie.WriteContrast(15);
genie.WriteObject(GENIE_OBJ_LED_DIGITS, 0, TempSetPoint * 10); // display default temp set point
myPID.SetMode(AUTOMATIC); //set up PID mode
myPID.SetTunings(Kp, Ki, Kd);
static long waitPeriod = millis(); //initialize waitperiod to do temperature measurement and PID computation
genie.DoEvents(); // This calls the library each loop to process the queued responses from the display
//read temperature value and write to LED Digits
if (millis() >= waitPeriod)
//genie.WriteObject(GENIE_OBJ_LED_DIGITS, 5, speedvalue);
// tempReadingTotal = 0;
// // Read 64 readings
// for (x = 0; x < 64; x++)
// tempReadingTotal += analogRead(tempPin);
//Divide by 64
// tempReading = tempReadingTotal / 64.0;
// double voltage = tempReading * 5000.0 / 1024.0;
temperatureC = thermocouple.readCelsius();
//temperatureC = (voltage - 500.0) / 10.0;
//write measured value to LED Digits and scope
genie.WriteObject(GENIE_OBJ_LED_DIGITS, 2, temperatureC*10);
genie.WriteObject(GENIE_OBJ_LED_DIGITS, 3, temperatureC*10);
genie.WriteObject(GENIE_OBJ_SCOPE, 0x00, (temperatureC-20)*2); //scope goes from 0 to 80. However, scale is from 20 to 60.
genie.WriteObject(GENIE_OBJ_SCOPE, 0x00, (TempSetPoint-20)*2);
//PID and heater control
if (RunHeater == true)
Input = temperatureC;
Setpoint = TempSetPoint;
myPID.Compute();
analogWrite(heaterPin, Output);
genie.WriteObject(GENIE_OBJ_LED_DIGITS, 4, Output/255*100);
analogWrite(heaterPin, 0);
genie.WriteObject(GENIE_OBJ_LED_DIGITS, 4, 0);
waitPeriod = millis() + 5000; // rerun this code after 5000 ms
// This is the user's event handler. It is called by genieDoEvents()
// when the following conditions are true
// The link is in an IDLE state, and
// There is an event to handle
// The event can be either a REPORT_EVENT frame sent asynchronously
// from the display or a REPORT_OBJ frame sent by the display in
// response to a READ_OBJ (genie.ReadObject) request.
void myGenieEventHandler(void)
genieFrame Event;
genie.DequeueEvent(&Event);
//Filter Events from Keyboard0 (Index = 0) for setting Temperature
//genie.EventIs usage: genie.EventIs(&Event,GENIE_REPORT_XX,GENIE_OBJ_XX,index of object).
if (genie.EventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_KEYBOARD, 0))
temp = genie.GetEventData(&Event); // Receive the event data from the Keyboard
if (temp >= 48 && temp <= 57 && counter <= 5)
keyvalue[counter] = temp;
genie.WriteStr(1, keyvalue); //prints to String Object
counter = counter + 1; //increment array
else if (temp == 110) // . key
keyvalue[counter] = '.'; // Receive the event data from the keyboard
else if (temp == 8) // backspace
counter--;
else if (temp == 13) //enter key = 13
//genie.WriteStr(0,keyvalue);
TempSetPoint = atof(keyvalue);
genie.WriteObject(GENIE_OBJ_FORM, 0x00, 0); //switch back to form 0
for (int x = 0; x < counter ; x++)
keyvalue[x] = 0;
counter = 0;
genie.WriteObject(GENIE_OBJ_LED_DIGITS, 0, TempSetPoint * 10); // Write Keyboard0 value to to LED Digits (temperature set point)
if (genie.EventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_WINBUTTON, 1)) //back to main WINBUTTON
if (genie.EventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_WINBUTTON, 3)) //back to main WINBUTTON
if (genie.EventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_WINBUTTON, 5)) //back to main WINBUTTON
//Filter Events from 4DButton0 (Index = 0) for starting heater
if (genie.EventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_4DBUTTON, 0))
RunHeater = genie.GetEventData(&Event);
genie.WriteObject(GENIE_OBJ_4DBUTTON, 2, RunHeater);
if (genie.EventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_4DBUTTON, 2))
genie.WriteObject(GENIE_OBJ_4DBUTTON, 0, RunHeater);
