Arduino Easy VR Module Upload Errors
Hello, recently I have encountered numerous problems with the VeeaR EasyVR Shield, after downloading all necessary software, I recorded various commands into the VR shield, this went smoothly however I am finding issues when uploading the programming to go with the Easy Vr Shield, I have received the same issues when uploading onto either of my Mega 2560 boards or my Arduino Uno, I am running the Arduino 1.5.2 software and the correct drivers for each board.
This is my code I am attempting to upload:
#include "Arduino.h"
#include "SoftwareSerial.h"
SoftwareSerial port(12,13);
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
  GROUP_3  = 3,
enum Group0
  G0_ROBOT= 0,
enum Group1
  G1_MOVE = 0,
  G1_TIME = 1,
  G1_DATE = 2,
  G1_LOCATION = 3,
  G1_TEMPERATURE = 4,
  G1_COLOUR = 5,
  G1_HUMIDITY = 6,
  G1_MOTION = 7,
  G1_DISTANCE = 8,
  G1_BEARING = 9,
  G1_POWER = 10,
  G1_AIR = 11,
  G1_DISPLAY = 12,
  G1_QUESTION = 13,
  G1_MANUAL = 14,
  G1_AUTO = 15,
  G1_RUN = 16,
  G1_POWERDOWN = 17,
  G1_WAKEUP = 18,
enum Group3
  G3_LEFT = 0,
  G3_RIGHT = 1,
  G3_FORWARD = 2,
  G3_BACKWARD = 3,
  G3_FOLLOW = 4,
  G3_STOP = 5,
  G3_GRAB = 6,
EasyVRBridge bridge;
int8_t group, idx;
  // bridge mode?
  if (bridge.check())
    cli();
    bridge.loop(0, 1, 12, 13);
  // run normally
  port.begin(9600);
  Serial.println("setup good");
  if (!easyvr.detect())
    Serial.println("EasyVR not detected!");
    for (;;);
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(0);
  group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
    // built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      Serial.print("Error ");
      Serial.println(err, HEX);
void action()
    switch (group)
    case GROUP_0:
      switch (idx)
      case G0_ROBOT:
        // write your action code here
        digitalWrite(8,HIGH); // LED to tell me if this is working
        Serial.println("IT WORKS");
        group = GROUP_1;
        delay(10);
        digitalWrite(8,LOW);
        // group = GROUP_X; <-- or jump to another group X for composite commands
    case GROUP_1:
      switch (idx)
      case G1_MOVE:
        digitalWrite(7, HIGH); // LED to tell me if this is working
        digitalWrite(7, LOW);
        Serial.println("YES");
      case G1_TIME:
      case G1_DATE:
      case G1_LOCATION:
      case G1_TEMPERATURE:
      case G1_COLOUR:
      case G1_HUMIDITY:
      case G1_MOTION:
      case G1_DISTANCE:
      case G1_BEARING:
      case G1_POWER:
      case G1_AIR:
      case G1_DISPLAY:
      case G1_QUESTION:
      case G1_MANUAL:
          digitalWrite(6, HIGH); // LED's to tell me this is working
        digitalWrite(6, LOW);
      case G1_AUTO:
      case G1_RUN:
      case G1_POWERDOWN:
      case G1_WAKEUP:
    case GROUP_3:
      switch (idx)
      case G3_LEFT:
      case G3_RIGHT:
      case G3_FORWARD:
      case G3_BACKWARD:
      case G3_FOLLOW:
      case G3_STOP:
      case G3_GRAB:
After uploading this I receive the following error messages:
avrdude: stk500v2_RecieveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
More recently I have begun to only receive the ‘famous’ -
avrdude: stk500v2_getsync(): resp=0x00
  • error upon uploading, however I am unsure how related these two error messages are.
I am a competent programmer however I may simply be making a rookie error here or most likely there is an issue with my EasyVR Shield, considering that the example code from the library also results in the same upload errors I think this is most likely the case, however any advice would be greatly appreciated here :slight_smile:
Does it upload to the Arduino without the VR Shield attached?
Have you checked that the correct board is selected under "Tools>Board?"
I have some experience with the EasyVR shield and willing to help.
Thank you very much, yes the correct port has been selected and yes the program will upload to the board without the Vr Shield attached, I tried uploading the program to the mega/uno and then attaching the shield however when I connect the power I only receive a solitary ' w ' through the serial display I am unsure if this is a fault message or just a start up bug of the Vr, other than that I have no success with the Vr shield apart from the LED telling me it is on. :~
What are the jumpers set to on the shield?
Do you mean the UP, PC, HW and SW double male headers to the right of the logo on the shield? If so then there is a connector between the first and second rows of the PC pin, sorry if this is not what you mean...
Move that jumper to SW and try it again.
[u]Thank you[/u] very much it works perfectly now, uploads and reads commands correctly, very much appreciated and thanks for the quick feedback!!! :D
