hey,
i am using arduino with EasyVR for one of my college projects. I am working over it from weeks, so i know basics of EasyVR
But there’s a little a little problem, which i am not able to overcome.
In particular its not a problem,
Actually can anybody tell me how can i make a particular command/action keep on executing until a new command is heard. for example, i spoke LED_BLINK, and i want that LED keeps on blinking until a new command for different group is heard !!
i am using EasyVr commander 3.6.22 for training commands and generating .pde(arduino ) code !
here’s code
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#include "SoftwareSerial.h"
SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
#include "WProgram.h"
#include "NewSoftSerial.h"
NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_START = 0,
enum Group1
G1_LED_BLINK = 0,
EasyVRBridge bridge;
int8_t group, idx;
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
port.begin(9600);
if (!easyvr.detect())
Serial.println("EasyVR not detected!");
for (;;);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
easyvr.setLanguage(0);
group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
do
//Serial.println("can do some processing while waiting for a spoken command");
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
Serial.print("built in triggr, robot");
// built-in trigger (ROBOT)
// group = GROUP_X; <-- jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: ");
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(" = ");
Serial.println(name);
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println("Timed out, try again...");
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
void action()
switch (group)
case GROUP_0:
switch (idx)
case G0_START:
// write your action code here
group=GROUP_1; // group = GROUP_X; <-- or jump to another group X for composite commands
case GROUP_1:
switch (idx)
case G1_LED_BLINK:
digitalWrite(13,HIGH);
delay(150);
digitalWrite(13,LOW);
delay(150);
thank you !!
