Arduino/EasyVR unable to read commands
Hi all,
I am currently doing a small mini project which enables me to control the light of my leds / fan to turn on and off with my voice command. I have train all the commands in the EasyVR, but after i change the pin to SW mode, it didn’t respond to my voice. For in this instance when i said CLOVER, the easyvr shield does not read me. Can anyone explain why? Thanks appreciate.
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #include "SoftwareSerial.h"
  SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
  #include "WProgram.h"
  #include "NewSoftSerial.h"
  NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_CLOVER = 0,
enum Group1
  G1_RED_ON = 0,
  G1_GREEN_ON = 1,
  G1_YELLOW_ON = 2,
  G1_RED_OFF = 3,
  G1_GREEN_OFF = 4,
  G1_YELLOW_OFF = 5,
  G1_RED_BLINK = 6,
  G1_GREEN_BLINK = 7,
  G1_YELLOW_BLINK = 8,
  G1_FAN_ON = 9,
  G1_FAN_OFF = 10,
  G1_SHUT_DOWN = 11,
  G1_ON_ALL = 12,
EasyVRBridge bridge;
int8_t group, idx;
  // bridge mode?
  if (bridge.check())
    cli();
    bridge.loop(0, 1, 12, 13);
  // run normally
  port.begin(9600);
  if (!easyvr.detect())
    Serial.println("EasyVR not detected!");
    for (;;);
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(0);
  group = EasyVR::TRIGGER; //<-- start group (customize)
        pinMode(8, OUTPUT);
  digitalWrite(8, LOW);    // set the LED off
      pinMode(9, OUTPUT);
  digitalWrite(9, LOW);    // set the LED off
      pinMode(10, OUTPUT);
  digitalWrite(10, LOW);    // set the LED off
      pinMode(11, OUTPUT);
  digitalWrite(11, LOW);    // set the LED off
void action();
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
    // built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      Serial.print("Error ");
      Serial.println(err, HEX);
                    group = GROUP_0;
void action()
    switch (group)
    case GROUP_0:
      switch (idx)
      case G0_CLOVER:
        // write your action code here
        group = GROUP_1;// <-- or jump to another group X for composite commands
    case GROUP_1:
      switch (idx)
      case G1_RED_ON:
        group = GROUP_0; //<-- or jump to another group X for composite commands
                 digitalWrite(9, HIGH);    // set the LED on
      case G1_GREEN_ON:
                 digitalWrite(10, HIGH);   // set the LED on
      case G1_YELLOW_ON:
                 digitalWrite(11, HIGH);   // set the LED on
      case G1_RED_OFF:
                 digitalWrite(9, LOW);   // set the LED on
      case G1_GREEN_OFF:
                 digitalWrite(10, LOW);   // set the LED on
      case G1_YELLOW_OFF:
                 digitalWrite(11, LOW);   // set the LED on
      case G1_RED_BLINK:
  digitalWrite(9, LOW);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(9, HIGH);    // turn the LED off by making the voltage LOW
      case G1_GREEN_BLINK:
  digitalWrite(10, LOW);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(10, HIGH);    // turn the LED off by making the voltage LOW
      case G1_YELLOW_BLINK:
  digitalWrite(11, LOW);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(11, HIGH);    // turn the LED off by making the voltage LOW
  delay(1000);               // wait for a second// write your action code here
        group = GROUP_0; // <-- or jump to another group X for composite commands
      case G1_FAN_ON:
        group = GROUP_0;// <-- or jump to another group X for composite commands
        digitalWrite(8, HIGH);    // turn the LED off by making the voltage LOW
      case G1_FAN_OFF:
       digitalWrite(8, LOW);   // turn the LED on (HIGH is the voltage level)
      case G1_SHUT_DOWN:
      case G1_ON_ALL:
               digitalWrite(8, HIGH);   // turn the LED on (HIGH is the voltage level)
