Arduino + eclipse
I am trying to build my project using eclipse IDE. To configure my project I followed this tutorial: Arduino Playground - Eclipse
I am able to build my project but I encounter some trouble with the micros() function which always returns 0.
I'am using an arduino mega 2560.
Do you have any idea why this function always returns 0 ?
Thanks.
Does the code work correctly when compiled using the IDE?
We have, of course, no idea where you are calling micros().
Yes the code compile without any problem using the arduino IDE.
In fact I can reproduce the bug with the following code using the arduino IDE:
  delay(2000);
  Serial.println("ok");
Note that the micros() function is called by delay().
I tried to replicate your problem. I found something interesting. If you sometimes use a dual monitor setup, and put the Serial Monitor on the second monitor, there is no way to move it if you do not have that second monitor attached. I use two monitors at work, but only one at home. The last time I opened the Serial Monitor, I moved it to the other monitor. Now, I can not move it back, or see it. Hard to see how often the statement is printed to the serial monitor when you can not see the serial monitor.
niorf:
Make sure you call init(). This sets up the timer that the counter runs off. e.g. to imitate the Arduino IDE:
#include <wiring.h>   // from the Arduino library
int main(int argc,char **argv) {
  init();
  setup();
  for(;;)
    loop();
  return 0; // not reached
PaulS:
Assuming you're on Windows...
  • Select the serial monitor in the task bar. It will come to the foreground on the invisible monitor.
  • Press Alt-Space to drop down the system menu.
  • Press M to start moving it.
  • Use the cursor arrows to move it back to the primary monitor. Actually after you've pressed any cursor at least once you can then use the mouse to swing it back into view.
NB. If you have it maximised on the invisible monitor you'll need to do Alt-Space, R to restore it before moving it.
I didn't call init() !!
Now I got another issue: the opposite of the first one :slight_smile:
The following code don't wait 2 seconds to print "OK".
=> the delay function does not block...
int main() {
	init();
	while (true) {
		Serial.println("OK");
		delay(2000);
Stupid mistakes ! (one more zero was insterted into the gcc option -DF_CPU=16000000UL)
All works fine now !!!
Thanks a lot for you help.
