Arduino Encoder Library Issue
For my robot, I am running two 12v Motor with an Encoder from Pololu with a 29:1 gear ratio. In order to read the encoder values, I used this library (Encoder Library, for Measuring Quadarature Encoded Position or Rotation Signals) to read values to prevent the Arduino program from crashing. I essentially copy and pasted the sample code and made it into a function for my program and it worked fine. A couple of weeks later, when I get back to working with the encoders, I am getting readings on 0-1 and 1-0 every time I turn the left motor. If I flash the basic sample, both encoder values work without and issue. Is there anything that could be causing the 0-1 and 1-0 transition? I have an Arduino Mega and I tried using the other interrupt pins ((2, 3), I am currently using (18, 19) and (20, 21)). Here is the code for the function that is called in loop():
/* Encoder Library - TwoKnobs Example
 * http://www.pjrc.com/teensy/td_libs_Encoder.html
 * This example code is in the public domain.
#include <Encoder.h>
// Change these pin numbers to the pins connected to your encoder.
//   Best Performance: both pins have interrupt capability
//   Good Performance: only the first pin has interrupt capability
//   Low Performance:  neither pin has interrupt capability
Encoder knobLeft(18, 19);
Encoder knobRight(20, 21);
//   avoid using pins with LEDs attached
  Serial.println("TwoKnobs Encoder Test:");
long positionLeft  = -999;
long positionRight = -999;
  long newLeft, newRight;
  newLeft = knobLeft.read();
  newRight = knobRight.read();
  if (newLeft != positionLeft || newRight != positionRight) {
    Serial.print("Left = ");
    Serial.print(newLeft);
    Serial.print(", Right = ");
    Serial.print(newRight);
    positionLeft = newLeft;
    positionRight = newRight;
  // if a character is sent from the serial monitor,
  // reset both back to zero.
  if (Serial.available()) {
    Serial.read();
    Serial.println("Reset both knobs to zero");
    knobLeft.write(0);
    knobRight.write(0);
When I swap (18,19) with (20,21), only the variable knobRight is reading correctly so I know it isn't an issue with the encoders themselves. Any help on what could be causing this issue would be greatly appreciated. Thanks.
