Hi All Arduino Users
I’m trying to upload the code to the board and I got this error:
arduino error: expected primary-expression before ' ' token
Code looks fine for me and I don’t know where is problem. Anyone could help me?
Here is all code:
#include <SPI.h>
#include <SD.h>
#include <string.h>
#include <Keyboard.h>
File myFile;
boolean first = true;
String dip = ""; // Name of the file that will be opened
// Sets the given pins as switches for the dip switches
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
// Switches are checked, dip string is contructed
if (digitalRead(6) == LOW){dip += "1";} else {dip += "0";}
if (digitalRead(7) == LOW){dip += "1";} else {dip += "0";}
if (digitalRead(8) == LOW){dip += "1";} else {dip += "0";}
if (digitalRead(9) == LOW){dip += "1";} else {dip += "0";}
dip += ".txt";
if (!SD.begin(4)) {
return;
// Desired file is opened
myFile = SD.open(dip);
if (myFile) {
Keyboard.begin();
String line = "";
while (myFile.available()) {
char m = myFile.read();
if (m == '\n'){
Line(line);
line = "";
else if((int) m != 13)
line += m;
Line(line);
myFile.close();
Keyboard.end();
void Line(String l)
int space_1 = l.indexOf(" ");
if (space_1 == -1)
Press(l);
else if (l.substring(0,space_1) == "STRING")
Keyboard.print(l.substring(space_1 + 1));
else if (l.substring(0,space_1) == "DELAY")
int delaytime = l.substring(space_1 + 1).toInt();
delay(delaytime);
else if(l.substring(0,space_1) == "REM"){}
String remain = l;
while(remain.length() > 0)
int latest_space = remain.indexOf(" ");
if (latest_space == -1)
Press(remain);
remain = "";
Press(remain.substring(0, latest_space));
remain = remain.substring(latest_space + 1);
delay(5);
Keyboard.releaseAll();
void Press(String b)
if(b.length() == 1)
char c = b[0];
Keyboard.press(c);
else if (b.equals("ENTER"))
Keyboard.press(KEY_RETURN);
else if (b.equals("CTRL"))
Keyboard.press(KEY_LEFT_CTRL);
else if (b.equals("SHIFT"))
Keyboard.press(KEY_LEFT_SHIFT);
else if (b.equals("ALT"))
Keyboard.press(KEY_LEFT_ALT);
else if (b.equals("GUI"))
Keyboard.press(KEY_LEFT_GUI);
else if (b.equals("UP") || b.equals("UPARROW"))
Keyboard.press(KEY_UP_ARROW);
else if (b.equals("DOWN") || b.equals("DOWNARROW"))
Keyboard.press(KEY_DOWN_ARROW);
else if (b.equals("LEFT") || b.equals("LEFTARROW"))
Keyboard.press(KEY_LEFT_ARROW);
else if (b.equals("RIGHT") || b.equals("RIGHTARROW"))
Keyboard.press(KEY_RIGHT_ARROW);
else if (b.equals("DELETE"))
Keyboard.press(KEY_DELETE);
else if (b.equals("PAGEUP"))
Keyboard.press(KEY_PAGE_UP);
else if (b.equals("PAGEDOWN"))
Keyboard.press(KEY_PAGE_DOWN);
else if (b.equals("HOME"))
Keyboard.press(KEY_HOME);
else if (b.equals("ESC"))
Keyboard.press(KEY_ESC);
else if (b.equals("INSERT"))
Keyboard.press(KEY_INSERT);
else if (b.equals("TAB"))
Keyboard.press(KEY_TAB);
else if (b.equals("END"))
Keyboard.press(KEY_END);
else if (b.equals("CAPSLOCK"))
Keyboard.press(KEY_CAPS_LOCK);
else if (b.equals("F1"))
Keyboard.press(KEY_F1);
else if (b.equals("F2"))
Keyboard.press(KEY_F2);
else if (b.equals("F3"))
Keyboard.press(KEY_F3);
else if (b.equals("F4"))
Keyboard.press(KEY_F4);
else if (b.equals("F5"))
Keyboard.press(KEY_F5);
else if (b.equals("F6"))
Keyboard.press(KEY_F6);
else if (b.equals("F7"))
Keyboard.press(KEY_F7);
else if (b.equals("F8"))
Keyboard.press(KEY_F8);
else if (b.equals("F9"))
Keyboard.press(KEY_F9);
else if (b.equals("F10"))
Keyboard.press(KEY_F10);
else if (b.equals("F11"))
Keyboard.press(KEY_F11);
else if (b.equals("F12"))
} <--------------------------This line is highlighted
// nothing happens after setup
I marked line which is highlighted after uploading and getting error. I tried to remove ‘}’, but it doesnt solved the problem. To be more specific I’m putting all console output below:
[color=orange]
C:\Users\7urtl3\Documents\Arduino\dipswitches\dipswitches.ino: In function 'void Press(String)':
dipswitches:232:3: error: expected primary-expression before '}' token
C:\Users\7urtl3\Documents\Arduino\dipswitches\dipswitches.ino: At global scope:
dipswitches:233:1: error: expected declaration before '}' token
Multiple libraries were found for "Keyboard.h"
Used: C:\Users\7urtl3\Documents\Arduino\libraries\Keyboard
Not used: C:\Program Files (x86)\Arduino\libraries\Keyboard
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
[/color]
Using library SD at version 1.2.3 in folder: C:\Program Files (x86)\Arduino\libraries\SD
Using library Keyboard in folder: C:\Users\7urtl3\Documents\Arduino\libraries\Keyboard (legacy)
Using library HID at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\HID
[color=orange]
exit status 1
[/color]
