This is my first forum post so please say something if I do this wrong.
I am making a project with the arduino mega 2560 and what I have so far is 2 buttons that turn a servo different directions and a motion sensor that turns on an led. The button/servo part was fine before I added the motion sensor code. Now it gives me the expected unqualified-id before 'if' error when I verify it. I've been trying to find the solution online, but cannot find it. I will provide the code and a screenshot of the error.
Thanks for your time!
Code:
#include <IRremote.h> //Ignor these, most of these libraries will be used later.
#include <RTClib.h>
#include <MFRC522.h>
#include <LiquidCrystal.h>
#include <Keypad.h>
#include <Servo.h>
#include <HCSR04.h>
#include <Stepper.h>
Servo servo;
const int sensor = 32; //Motion sensor
const int led = 31; //LED that the motion sensor turns on.
const int OffPin=24; //buttons
const int OnPin=23;
servo.attach(22);
servo.write(120);
pinMode(OffPin, OUTPUT);
pinMode(OnPin, OUTPUT);
pinMode(sensor, INPUT); //sensor put as INPUT
pinMode(led, OUTPUT);
void loop(){
int value = digitalRead(sensor); //value is the state of the motion sensor
if (value == HIGH){ //motion = led on for 2 seconds
digitalWrite(led, HIGH);
delay(2000);
digitalWrite(led, LOW);
else {
digitalWrite(led, LOW); //otherwise keep led off
if(digitalRead(OffPin)==HIGH){ //all of the code from here to the end worked fine before I added the code above
servo.write(80);
delay(200);
servo.write(120);
else if(digitalRead(OnPin)==HIGH){
servo.write(180);
delay(200);
servo.write(120);
delay(200);
servo.write(180);
delay(200);
servo.write(120);
else { //if no button is pressed, keep servo in neutral position and run the code again after 10ms
servo.write(120);
delay(10);
