Arduino error :Error:expected unqualified-id before numeric constant
I have an error message in my code, i am try to show serial monitor displayed to LCD 20x4. before add lcd script, arduino succesfull compile. but after input lcd crystal, showed "lvalue required as left operand of assignment
"anyone can help me?
#include <Wire.h>
#define MQ_sensor A0
LiquidCrystal_I2C lcd(0x27,20,2);
lcd.init();
Serial.println("NH3 in PPM");
Serial.println("TEST");
delay(3000);
float VRL = 0.0;
float Rs = 0.0;
float ratio = 0.0;
float RL = 47;
float m = -0.243;
float b = 0.42;
float Ro = 91.42;
unsigned int analog_value=0;
lcd.setCursor(0,0);
lcd.print("PPM");
for(int test_cycle = 1 ; test_cycle <= 500 ; test_cycle++)
analog_value = analog_value + analogRead(MQ_sensor);
delay(3);
float analog = float(analog_value)/500.0;
VRL = analog*(5.0/1023.0);
//Serial.println(VRL);
Rs = ((5.0 * RL) / VRL) - RL;
ratio = Rs / Ro;
float ppm = pow(10, ((log10(ratio) - b) / m));
lcd.setCursor(0,1);
lcd.print(ppm);
Serial.print("NH3 (ppm) = ");
Serial.println(ppm);
Serial.print("Voltage = ");
Serial.println("");
below is error message:
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:32:0,
from sketch\MK_2.ino.cpp:1:
C:\Users\asus\Documents\Arduino\sensor amoniak mk 1\MK_2\MK_2.ino: In function 'void loop()':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/binary.h:38:19: error: expected unqualified-id before numeric constant
#define B00000001 1
C:\Users\asus\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:53:12: note: in expansion of macro 'B00000001'
#define Rs B00000001 // Register select bit
C:\Users\asus\Documents\Arduino\sensor amoniak mk 1\MK_2\MK_2.ino:17:7: note: in expansion of macro 'Rs'
float Rs = 0.0;
MK_2:36:27: error: lvalue required as left operand of assignment
exit status 1
Change all occurrences of this variable to "rS".
By convention, variables do not start with a capital.
This is not a bootloader issue.
Please remember to use code tags when posting code
Apparently, Rs is a macro in the LiquidCrystal_I2C library. What happens when you rename that variable?
THANKS. It works
i only copy script that i found on internet.
Hopefully this script is not one of the official examples of the library then.
how to use code tags?
Your topic has been moved to a more suitable location on the forum as this has nothing to do with Avrdude, stk500 or Bootloader
Read How to get the best out of this forum
