Arduino error: expected unqualified-id before '<' token
The error appears in both the first and last lines. Someone please tell me how to fix the code from here on.
// include the library code #include
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// initialize our variables
int sensorPin = 0;
int tempC, tempF;
// set up the LCD’s number of columns and rows:
lcd.begin(16, 2);
tempC = get_temperature(sensorPin);
tempF = celsius_to_fahrenheit(tempC);
lcd.setCursor(0,0);
lcd.print(tempF); lcd.print(" "); lcd.print((char)223); lcd.print(“F”);
delay(200);
int get_temperature(int pin) {
// We need to tell the function which pin the sensor is hooked up to. We’re using
// the variable pin for that above
// Read the value on that pin
int temperature = analogRead(pin);
// Calculate the temperature based on the reading and send that value back
float voltage = temperature * 5.0;
voltage = voltage / 1024.0;
return ((voltage - 0.5) * 100);
int celsius_to_fahrenheit(int temp) {
return (temp * 9 / 5) + 32;
remove the HTML paragraph tags!
<p> </p>
Try adding to the top of your program:
#include <LiquidCrystal.h>
BulldogLowell:
Perfect thank you that worked.
