I own an Arduino Uno. I wated to uploud a file (no mistakes in the code) but then this error message popped up:
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x56
What does it mean and how do I fix it?
Thank you,
Philipp Anzböck
Thank you,
Philipp Anzböck
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
