as a beginner i am trying to control a brushless motor through arduino by using buttons, is this code correct?
button pressed spinning motor, button not pressed not moving
# include <Servo.h>
Servo m1;
int pushButton = 2;
pinMode(pushButton,2);
m1.attach(6);
delay(1);
m1.write(40);
void loop() {https://forum.arduino.cc/
int buttonState = digitalRead(pushButton);
Serial.println(buttonState);
delay(1);
m1.write(80);
That's right but I don't know if it is for the reason you think. What did you mean the 2 to represent here? The pin number? Or the constant INPUT_PULLUP?
delay(1);
m1.write(80);
You've got a comment hanging out on the first line here without being commented. That's going to throw an error. You read the button, that part is ok. You print the state and that's ok. And then you write 80 to the ESC regardless of what was going on with the button. To get what you describe in your post I would expect to see at least one if statement in there.
Take a look at the Button example. From the Arduino IDE:
File -> Examples -> Digital -> Button
better?
# include <Servo.h>
Servo m1;
int pushButton = 2;
m1.attach(6);
delay(1);
m1.write(40);
delay(1);
if (buttonState == HIGH) {
m1.write(80, HIGH);
m1.write(40, LOW);
Why are you putting HIGH and LOW in the write commands for the motor? Where have you seen one written like that?
What are the specs/data of your ESC?
We need to see how you have connected everything.
Thanks.. Tom...
its just regular Brushless ESC, http://www.e-fliterc.com/Products/Default.aspx?ProdID=EFLA1060B
high and low they are the state of the button, high button pressed, and low button not pressed,
# include <Servo.h>
Servo m1;
int pushButton = 2;
int pos = 0;
pinMode(pushButton, INPUT);
m1.attach(6);
delay(1);
m1.write(40);
if (digitalRead(pushButton) == HIGH) { //Opens the door when the 'open' button is pressed
m1.attach(9); //Gives the servo power
m1.write(70); //Tells servo to move to 0 degree mark
delay(1000); // waits 1000ms for the servo to reach the position
thank you, its working now, next step to use HC-05 rx tx, made on slave and one master, looking through it atm
# include <Servo.h>
Servo m1;
int pushButton = 2;
m1.attach(6);
delay(1);
m1.write(40);
if (digitalRead(pushButton) == HIGH > LOW) { //Opens the door when the 'open' button is pressed
m1.attach(6); //Gives the servo power
m1.write(90); //Tells servo to move to 0 degree mark
delay(1); // waits 1000ms for the servo to reach the position
m1.write(40);
delay(1);
