Arduino ESP32 FreeRTOS vTaskSuspend fails with print statements
Have only been a few days into FreeRTOS on Arduino ESP32, so please bear with me :slight_smile:
I encountered a strange behavior when trying out a simple FreeRTOS sketch running on a ESP32 WROVER module. esp32 core version is 2.0.6. At the start global variable count initiates at 1. The two tasks are:
  • red : increments the global variable count every 1 s , and toggles a red LED every 0.5 s. It is pinned to core 0. Note that there's a print statement printing the count value.
  • green : suspends the red tasks once count is greater than 5 , and toggles a green LED every 1 s. It is pinned to core 1.
Very strangly, with the print statement in green (line 51) commented out, vTaskSuspend(redHandle) does not suspend the red task as expected once count is over 5. Both LEDs keep toggling and the count continues to increment. It seems that only when the count is printed out with line 51 in the green task will red be actually suspended.
I'm not sure if this is a bug, a multicore issue, or a collision deep under between Serial and FreeRTOS. Can someone explain?
Full sketch as follows:
int count = 1;
TaskHandle_t redHandle;
  xTaskCreatePinnedToCore(
    red
    , "red"
    , 1024
    , NULL
    , 1
    , &redHandle
    , 0);
    green
    , "green"
    , 1024
    , NULL
    , 1
    , NULL
    , 1);
void red(void* param) {
  pinMode(13, OUTPUT);
  while (true) {
    count++;
    Serial.println(count);
    digitalWrite(13, HIGH);
    vTaskDelay(500 / portTICK_PERIOD_MS);
    digitalWrite(13, LOW);
void green(void* param) {
  pinMode(27, OUTPUT);
  while (true) {
    // Serial.println(count);
    if (count > 5) {
      vTaskSuspend(redHandle);
    digitalWrite(27, HIGH);
    vTaskDelay(1000 / portTICK_PERIOD_MS);
    digitalWrite(27, LOW);
The Espressif Official Arduino site:
ESP32 Forum - Search
I'm not so sure that this is an IDE problem. Hence moved to another section of the forum.
