Arduino esp8266: Clients is connected multiple times with TCP server
Hello,
I am using an esp8266 "ESPino(ESP-12 Module)" currently. I am trying to connect my microcontroller to a tcp server which I open using the Android App "TCP Server" from MightyIT. The connection gets established like I intended. However, each time I upload the sketch again, another connection is established with the same IP adress. The app now shows that there are multiple clients with the same IP adress. How can I preven this? Is there a way I can check if there is already a connecton established?
#include <ESP8266WiFi.h>
#define SendKey 0  //Button to send data Flash BTN on NodeMCU
int port = 3000;  //Port number
const IPAddress serverA(10,39,1,144);
//Server connect to WiFi Network
WiFiClient client;
const char *ssid = "********";  //My wifi ssid
const char *password = "*******";  //My wifi password
WiFiServer server(port);
int count=0;
//                    Power on setup
  delay(10);
  //WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password); //Connect to wifi
  // Wait for connection
  Serial.println("Connecting to Wifi");
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  Serial.println(port);
  if( not client.connected()){
      if(client.connect(serverA, port)){
    Serial.println("Connected Successfully");
  }else{
    Serial.print("Ups there was a problem");
    client.stop();
  }else{
    Serial.println("There is already a connection");
//                    Loop
  while(client.connected()){
    Serial.println("Still connected");
those connections time out in 10 minutes or so
