Arduino + ESP8266 not posting data using PHP to XAMPP SQL
I would like to ask some help about my error. I am trying to push sensor data into the sql of XAMPP with the use of ESP8266 and some php coding. I would like to know why my output is not pushing into the database. This database will be offline and only be on localhost so I will not worry about attacks because it is just in the local server.
This is my Arduino Code
#include <SoftwareSerial.h>
//------------------WIFI VALUES------------------------
SoftwareSerial esp8266(2, 3); // 2 = RX, 3 = TX
String ssid ="ScoobyDooby Network";
String password ="rapperjj20";
String server ="192.168.1.5"; //ip address of localhost
String uri = "/~Thesis/InsertData.php";
String data;
//------------------WIFI VALUES END--------------------
//------------------PH VALUES START------------------
#define SensorPin A5            //pH meter Analog output to Arduino Analog Input 2
#define Offset -1.00            //deviation compensate
unsigned long int avgValue;  //Store the average value of the sensor feedback
float b;
int buf[10],temp;
static float phValue;
//------------------PH VALUES END--------------------
void resetWifi() {
  esp8266.println("AT+RST");
  delay(2000);
  if(esp8266.find("OK") )
    Serial.println("Module Reset");
void connectWifi() {
  delay(2000);
  esp8266.println("AT+CWMODE=1");
  esp8266.println("AT+CIPMODE=0");
  esp8266.println("AT+CIPMUX=1");
  String cmd = "AT+CWJAP=\"" +ssid+"\",\"" + password + "\"";
  esp8266.println(cmd);
  delay(4000);
  if(esp8266.find("OK")){
    Serial.println("Connected!");
  else {
    Serial.println("Not connected!");
    connectWifi();
  esp8266.begin(115200);
  resetWifi();
  connectWifi();
void httppost() {
  esp8266.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");//start a TCP connection.
  delay(3000);
  if( esp8266.find("OK")) {
    Serial.println("TCP connection ready");
  String postRequest =
  "POST " + uri + " HTTP/1.0\r\n" +
  "Host: " + server + "\r\n" +
  "Accept: *" + "/" + "*\r\n" +
  "Content-Length: " + data.length()+ "\r\n" +
  "Content-Type: application/x-www-form-urlencoded\r\n" +
  "\r\n" + data;
  String sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
  esp8266.print(sendCmd);
  esp8266.println(postRequest.length());
  delay(3000);
  if(esp8266.find(">")) {
    Serial.println("Sending..");
    esp8266.print(postRequest);
    if(esp8266.find("OK")) {
      Serial.println("Packet sent");
      while (esp8266.available()) {
        String tmpResp = esp8266.readString();
        Serial.println(tmpResp);
      // close the connection
      esp8266.println("AT+CIPCLOSE");
//------------------PH METER CODES START------------------
  for(int i=0;i<10;i++)       //Get 10 sample value from the sensor for smooth the value
    buf[i]=analogRead(SensorPin);
    delay(10);
  for(int i=0;i<9;i++)        //sort the analog from small to large
    for(int j=i+1;j<10;j++)
      if(buf[i]>buf[j])
        temp=buf[i];
        buf[i]=buf[j];
        buf[j]=temp;
  avgValue=0;
  for(int i=2;i<8;i++)                      //take the average value of 6 center sample
    avgValue+=buf[i];
  phValue=(float)avgValue*5.0/1024/6; //convert the analog into millivolt
  phValue=3.5*phValue + Offset;                      //convert the millivolt into pH value
  Serial.print("    pH:");
  Serial.print(phValue);
  Serial.println(" ");
//------------------PH METER CODES END--------------------
         //------------------Convert the bit data to string form--------------------
String phValue1 = String(phValue);
Serial.print("pH Level: ");
  Serial.println(phValue1);
data = "x=" + phValue1; // data sent must be under this form //name1=value1&name2=value2.
Serial.print("DATA to be sent: ");
  Serial.println(data);
 httppost();
 //------------------Conversion ends----------------------------------------
This is my InsertData.php
<?php
 require_once 'conf.php';
    session_start();
 $read = array();
 //Data sent by arduino will be passed into this variable
 $Temp = $_POST["x"];
 $read = explode("-", $Temp);
 //Setting newt_textbox_set_height(textbox, height) default timezone
 date_default_timezone_set('Asia/Manila');
 $date = date("Y/m/d H:i:sa");
 //Inserting data to different table
 $phLevelSQL = 'INSERT INTO `phsensor` (`phLevel `,`dateRet`) VALUES ("'.$read[0].'", "'.$date.'")';
 //Inserting data to the database
 mysqli_query($connection, $phLevelSQL);
This is the conf.php
<?php
 $dbhost   ='localhost';
 $dbuser   ='arduino';
 $dbpass   ='thesis123';
 $dbname   ='arduino_thesis';
 $connection = mysqli_connect($dbhost,$dbuser,$dbpass,$dbname);
 if (mysqli_connect_errno()) {
 printf("Connect failed: %s\n", mysqli_connect_error());
 exit();
This is my Database
Finally this is the output.
I am not getting any data inserted into the table.
Can I ask for advice, help, and tips?
