Arduino, ESP8266 wifi module, and web server
I am trying to send my data to a web server by using eps8266 wifi module, and I have no idea how can I send my data to a web server by using this module. So now need some idea for, how to send my data to a web server.
hi do you read the examples?
who is the server and who is the client?
As @nik600 has said you need to start by getting some of the example programs to work.
If you can’t get an example to work, post the code and tell us what actually happens. And please use the code button </> so your code looks like this and is easy to copy to a text editor
How are you powering the ESP8266? - it requires a lot more current than the Arduino 3.3v pin can provide.
…R
Actually I am new at this platform. I just connect my esp8266 and Arduino, and it response when I give AT command. In my project there is a sensor, by using this sensor I read some data. Now I want to send those data to a server using this wifi module, and I have no idea how to send data by using this module, though i'm now in a beginner level couldn't find similar example for this. (I did not send any data to server from arduino before,and I never did this kind of works before.) So if you have any idea then please let me know. It'll be much appreciable if anybody help me out by giving any kind of link or tutorial.
Asadujjaman: Actually I am new at this platform. I just connect my esp8266 and Arduino, and it response when I give AT command. In my project there is a sensor,
For the moment, ignore the sensor. Just figure out how to send a message (such as "Hello Johnny") to a server.
Post a link to the website where you have got your ESP8266 example programs.
...R
Actually I did not find any example which can send msg to a server by using this ESP8266 module. All examples are like sending msg or data to a web page by using this module. Here is one example I have found which can send email by using this module.
code link: "https://github.com/AllAboutEE/Adafruit_ESP8266/blob/master/examples/send_email_smtp/send_email_smtp.ino"
And I have also found this example which can send msg to a web Page. code: "http://allaboutee.com/2014/12/30/esp8266-and-arduino-webserver/" youtube Link : "https://www.youtube.com/watch?v=q02f4sPghSo"
I think the last example is close enough to my problem. Can you please suggest me what should I do now .
This seems to be the code from your second example (in future please post code in this Forum to make it easier to help you).
#include <SoftwareSerial.h>
#define DEBUG true
SoftwareSerial esp8266(2,3); // make RX Arduino line is pin 2, make TX Arduino line is pin 3.
                             // This means that you need to connect the TX line from the esp to the Arduino's pin 2
                             // and the RX line from the esp to the Arduino's pin 3
  esp8266.begin(9600); // your esp's baud rate might be different
  sendData("AT+RST\r\n",2000,DEBUG); // reset module
  sendData("AT+CWMODE=2\r\n",1000,DEBUG); // configure as access point
  sendData("AT+CIFSR\r\n",1000,DEBUG); // get ip address
  sendData("AT+CIPMUX=1\r\n",1000,DEBUG); // configure for multiple connections
  sendData("AT+CIPSERVER=1,80\r\n",1000,DEBUG); // turn on server on port 80
  if(esp8266.available()) // check if the esp is sending a message
    while(esp8266.available())
      // The esp has data so display its output to the serial window
      char c = esp8266.read(); // read the next character.
      Serial.write(c);
    if(esp8266.find("+IPD,"))
     int connectionId = esp8266.read()-48; // subtract 48 because the read() function returns
                                           // the ASCII decimal value and 0 (the first decimal number) starts at 48
     String webpage = "<h1>Hello</h1>&lth2>World!</h2><button>LED1</button>";
     String cipSend = "AT+CIPSEND=";
     cipSend += connectionId;
     cipSend += ",";
     cipSend +=webpage.length();
     cipSend +="\r\n";
     sendData(cipsend,1000,DEBUG);
     sendData(webpage,1000,DEBUG);
     webpage="<button>LED2</button>";
     cipSend += ",";
     cipSend +="\r\n";
     String closeCommand = "AT+CIPCLOSE=";
     closeCommand+=connectionId; // append connection id
     closeCommand+="\r\n";
     sendData(closeCommand,3000,DEBUG);
String sendData(String command, const int timeout, boolean debug)
    String response = "";
    esp8266.print(command); // send the read character to the esp8266
    long int time = millis();
    while( (time+timeout) > millis())
        response+=c;
    if(debug)
      Serial.print(response);
    return response;
As far as I can see that sets up the ESP8266 to operate as a server and I don’t think that’s what you want - I think you want it to act as a client for some other server.
I will try to do a bit of Googling on your behalf to see if there is a better example.
…R
This is maybe closer to what you want to do.
  Adafruit MQTT Library ESP8266 Example
  Must use ESP8266 Arduino from:
    https://github.com/esp8266/Arduino
  Works great with Adafruit's Huzzah ESP board:
  ----> https://www.adafruit.com/product/2471
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Tony DiCola for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "...your SSID..."
#define WLAN_PASS       "...your password..."
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "...your AIO username (see https://accounts.adafruit.com)..."
#define AIO_KEY         "...your AIO key..."
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// Store the MQTT server, client ID, username, and password in flash memory.
// This is required for using the Adafruit MQTT library.
const char MQTT_SERVER[] PROGMEM    = AIO_SERVER;
// Set a unique MQTT client ID using the AIO key + the date and time the sketch
// was compiled (so this should be unique across multiple devices for a user,
// alternatively you can manually set this to a GUID or other random value).
const char MQTT_CLIENTID[] PROGMEM  = __TIME__ AIO_USERNAME;
const char MQTT_USERNAME[] PROGMEM  = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM  = AIO_KEY;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_CLIENTID, MQTT_USERNAME, MQTT_PASSWORD);
/****************************** Feeds ***************************************/
// Setup a feed called 'photocell' for publishing.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
const char PHOTOCELL_FEED[] PROGMEM = AIO_USERNAME "/feeds/photocell";
Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt, PHOTOCELL_FEED);
// Setup a feed called 'onoff' for subscribing to changes.
const char ONOFF_FEED[] PROGMEM = AIO_USERNAME "/feeds/onoff";
Adafruit_MQTT_Subscribe onoffbutton = Adafruit_MQTT_Subscribe(&mqtt, ONOFF_FEED);
/*************************** Sketch Code ************************************/
  delay(10);
  Serial.println(F("Adafruit MQTT demo"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
    Serial.print(".");
  Serial.println("WiFi connected");
  Serial.println("IP address: "); Serial.println(WiFi.localIP());
  // Setup MQTT subscription for onoff feed.
  mqtt.subscribe(&onoffbutton);
uint32_t x=0;
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  // Try to ping the MQTT server
  if (! mqtt.ping(3) ) {
    // MQTT pings failed, lets reconnect
    Serial.println("Ping fail!");
  // this is our 'wait for incoming subscription packets' busy subloop
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(1000))) {
    if (subscription == &onoffbutton) {
      Serial.print(F("Got: "));
      Serial.println((char *)onoffbutton.lastread);
  // Now we can publish stuff!
  Serial.print(F("\nSending photocell val "));
  Serial.print(x);
  Serial.print("...");
  if (! photocell.publish(x++)) {
    Serial.println(F("Failed"));
    Serial.println(F("OK!"));
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
  Serial.println("MQTT Connected!");
I just remembered that I had recently tried some example code for another Thread. This is the Library website and this is the particular example (from that website) that I tried successfully
 * @example HTTPGET.ino
 * @brief The HTTPGET demo of library WeeESP8266.
 * @author Wu Pengfei<pengfei.wu@itead.cc>
 * @date 2015.03
 * @par Copyright:
 * Copyright (c) 2015 ITEAD Intelligent Systems Co., Ltd. \n\n
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation; either version 2 of
 * the License, or (at your option) any later version. \n\n
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 * THE SOFTWARE.
#include "ESP8266.h"
#define SSID        "xxxxxx"     // provide your own SSID and PASSWORD
#define PASSWORD    "xxxxxx"
#define HOST_NAME   "www.baidu.com"
#define HOST_PORT   (80)
//~ #define HOST_NAME   "192.168.0.100"
//~ #define HOST_PORT   (8085)
ESP8266 wifi(Serial1);
void setup(void)
    Serial.print("setup begin\r\n");
    Serial.print("FW Version:");
    Serial.println(wifi.getVersion().c_str());
    if (wifi.setOprToStationSoftAP()) {
        Serial.print("to station + softap ok\r\n");
        Serial.print("to station + softap err\r\n");
    if (wifi.joinAP(SSID, PASSWORD)) {
        Serial.print("Join AP success\r\n");
        Serial.print("IP:");
        Serial.println( wifi.getLocalIP().c_str());
        Serial.print("Join AP failure\r\n");
    if (wifi.disableMUX()) {
        Serial.print("single ok\r\n");
        Serial.print("single err\r\n");
    Serial.print("setup end\r\n");
void loop(void)
    uint8_t buffer[1024] = {0};
    if (wifi.createTCP(HOST_NAME, HOST_PORT)) {
        Serial.print("create tcp ok\r\n");
        Serial.print("create tcp err\r\n");
    char *hello = "GET / HTTP/1.1\r\nHost: www.baidu.com\r\nConnection: close\r\n\r\n";
    //~ char *hello = "GET / HTTP/1.1\r\nHost: 192.168.0.100:8085\r\nConnection: close\r\n\r\n";
    wifi.send((const uint8_t*)hello, strlen(hello));
    uint32_t len = wifi.recv(buffer, sizeof(buffer), 10000);
    if (len > 0) {
        Serial.print("Received:[");
        for(uint32_t i = 0; i < len; i++) {
            Serial.print((char)buffer[i]);
        Serial.print("]\r\n");
    if (wifi.releaseTCP()) {
        Serial.print("release tcp ok\r\n");
        Serial.print("release tcp err\r\n");
    while(1);
If you can get that working it will be a useful starting point. Don’t omit to install the library - or at least include ESP8266.h and ESP8266.cpp in your project directory.
This code works with a Mega using Serial1 to communicate with the ESP8266. I think if you have an Uno you just need to create a SoftwareSerial instance called Serial1
…R
