Arduino Esplora and Lynxmotion SSC-32 help
I connected Arduino Esplora to SSC-32 board made by Lynxmotion. I can use the thumbstick to move my robot. I think that there's a problem with the Arduino code. If I comment out the else parts of the code, the robot walks correctly. If I don't comment out the else parts of the code, there is a slight pause in the walking movement. How can I fix the problem?
#include <Esplora.h>
  Serial1.begin(9600);
  robotstand01();
  if(Esplora.readButton(JOYSTICK_UP)==LOW)
    robotwalk01();
    robotwalk02();
    robotwalk03();
    robotwalk04();
    robotwalk05();
    robotwalk06();
  //else
  //  robotstand01();
  //  delay(1000);
  //delay(50);
  if(Esplora.readButton(JOYSTICK_DOWN)==LOW)
    robotwalk01();
    robotwalk02();
    robotwalk03();
    robotwalk04();
    robotwalk05();
    robotwalk06();
  //else
  //  robotstand01();
  //  delay(1000);
  //delay(50);
  if(Esplora.readButton(JOYSTICK_UP)==LOW || Esplora.readButton(JOYSTICK_DOWN)==LOW)
    robotstand01();
void move(int servo, int position, int time)
  Serial1.print("#");
  Serial1.print(servo);
  Serial1.print(" P");
  Serial1.print(position);
  Serial1.print(" T");
  Serial1.println(time);
void robotstand01()
  move(0,1500,1000);
  move(1,1500,1000);
  move(2,1500,1000);
  move(3,1500,1000);
  move(4,1500,1000);
  move(5,1500,1000);
  move(16,1500,1000);
  move(17,1500,1000);
  move(18,1500,1000);
  move(19,1500,1000);
  move(20,1500,1000);
  move(21,1500,1000);
void robotwalk01()
  move(0,1167,1000);
  move(1,1667,1000);
  move(2,1833,1000);
  move(3,1500,1000);
  move(4,1167,1000);
  move(5,1667,1000);
  move(16,1167,1000);
  move(17,1500,1000);
  move(18,1833,1000);
  move(19,1667,1000);
  move(20,1167,1000);
  move(21,1500,1000);
void robotwalk02()
  move(0,1167,1000);
  move(1,1500,1000);
  move(2,1833,1000);
  move(3,1500,1000);
  move(4,1167,1000);
  move(5,1500,1000);
  move(16,1167,1000);
  move(17,1500,1000);
  move(18,1833,1000);
  move(19,1500,1000);
  move(20,1167,1000);
  move(21,1500,1000);
void robotwalk03()
  move(0,1167,1000);
  move(1,1500,1000);
  move(2,1833,1000);
  move(3,1667,1000);
  move(4,1167,1000);
  move(5,1500,1000);
  move(16,1167,1000);
  move(17,1667,1000);
  move(18,1833,1000);
  move(19,1500,1000);
  move(20,1167,1000);
  move(21,1667,1000);
void robotwalk04()
  move(0,1833,1000);
  move(1,1500,1000);
  move(2,1167,1000);
  move(3,1667,1000);
  move(4,1833,1000);
  move(5,1500,1000);
  move(16,1833,1000);
  move(17,1667,1000);
  move(18,1167,1000);
  move(19,1500,1000);
  move(20,1833,1000);
  move(21,1667,1000);
void robotwalk05()
  move(0,1833,1000);
  move(1,1500,1000);
  move(2,1167,1000);
  move(3,1500,1000);
  move(4,1833,1000);
  move(5,1500,1000);
  move(16,1833,1000);
  move(17,1500,1000);
  move(18,1167,1000);
  move(19,1500,1000);
  move(20,1833,1000);
  move(21,1500,1000);
void robotwalk06()
  move(0,1833,1000);
  move(1,1667,1000);
  move(2,1167,1000);
  move(3,1500,1000);
  move(4,1833,1000);
  move(5,1667,1000);
  move(16,1833,1000);
  move(17,1500,1000);
  move(18,1167,1000);
  move(19,1667,1000);
  move(20,1833,1000);
  move(21,1500,1000);
You have two
delay(50)
that are commented out, yet not inside the else clauses. So when uncommented, you will always have a 100ms delay. Are these perhaps the culprit? Maybe delete those, or move them inside the else clauses?
