Arduino Esplora Visualisation in Processing
we're doing a project for school with our Arduino Esplora and try to visualate the axis in Processing based on a cube.
It's not our code and we don't know so much about programming with Processing, so we really need your help. :frowning:
If we run the program, the "cube" won't move. We think the program can't read the axis and it's just a failure in the code.
Here's the processing code:
* ADXL345 Library Examples- pitch_roll.pde                                      *
* Copyright (C) 2012 Anil Motilal Mahtani Mirchandani(anil.mmm@gmail.com)       *
* License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> *
* This is free software: you are free to change and redistribute it.            *
* There is NO WARRANTY, to the extent permitted by law.                         *
// If you are working with Arduino Mega
// sudo ln -s /dev/ttyACM0 /dev/ttyS8
import processing.serial.*;
Serial fd;
int pitch = 0;
int roll = 0;
int yaw = 0;
void setup ()
size(640, 360, P3D);
//Connect to the corresponding serial port
fd = new Serial(this, "COM6", 9600);
// Defer callback until new line
fd.bufferUntil('\n');
void draw ()
  //Set background
  background(0.5);
  pushMatrix();
  translate(width/2, height/2, -30);
  //Rotate
  rotateX(((float)pitch)*PI/180.0);
  rotateZ(((float)roll)*PI/180.0);
  rotateY(((float)yaw)*PI/180.0);
  //Print data
  print("Pitch: ");
  print(pitch);
  print(", Roll: ");
  println(roll);
  print("Yaw: ");
  println(yaw);
  scale(90);
  beginShape(QUADS);
  fill(0, 255, 0); vertex(-1,  1,  1);
  fill(0, 255, 0); vertex( 1,  1,  1);
  fill(0, 255, 0); vertex( 1, -1,  1);
  fill(0, 255, 0); vertex(-1, -1,  1);
  fill(0, 255, 255); vertex( 1,  1,  1);
  fill(0, 255, 255); vertex( 1,  1, -1);
  fill(0, 255, 255); vertex( 1, -1, -1);
  fill(0, 255, 255); vertex( 1, -1,  1);
  fill(255, 0, 255); vertex( 1,  1, -1);
  fill(255, 0, 255); vertex(-1,  1, -1);
  fill(255, 0, 255); vertex(-1, -1, -1);
  fill(255, 0, 255); vertex( 1, -1, -1);
  fill(255, 255, 0); vertex(-1,  1, -1);
  fill(255, 255, 0); vertex(-1,  1,  1);
  fill(255, 255, 0); vertex(-1, -1,  1);
  fill(255, 255, 0); vertex(-1, -1, -1);
  fill(255, 0, 0); vertex(-1,  1, -1);
  fill(255, 0, 0); vertex( 1,  1, -1);
  fill(255, 0, 0); vertex( 1,  1,  1);
  fill(255, 0, 0); vertex(-1,  1,  1);
  fill(0, 0, 255); vertex(-1, -1, -1);
  fill(0, 0, 255); vertex( 1, -1, -1);
  fill(0, 0, 255); vertex( 1, -1,  1);
  fill(0, 0, 255); vertex(-1, -1,  1);
  endShape();
  popMatrix();
void serialEvent (Serial fd)
  // get the ASCII string:
  String rpstr = fd.readStringUntil('\n');
  if (rpstr != null) {
    String[] list = split(rpstr, ':');
    pitch = ((int)float(list[0]));
    roll = ((int)float(list[1]));
    yaw = ((int)float(list[2]));
and our Arduino code to only read and print the axis and temperature:
 Verschiedene Temperaturen messen und via LED ausgeben
#include <Esplora.h>
  Serial.begin(9600);        // Initialisiere Kommunikation mit Computer
  // Temperatur einlesen
  int celsius = Esplora.readTemperature(DEGREES_C);
  // Temperatur ausgeben
  Serial.print("Temperatur betraegt ");
  Serial.print(celsius);
  Serial.println(" Grad Celsius");
  Serial.println("");
  // 0 Grad und weniger: Blaue LED
  if (celsius <= 0)
  { Esplora.writeRGB (0,0,205); }
  // Zwischen 0 und 21 Grad: Lila LED
  if (celsius >= 21)
  { Esplora.writeRGB (255,0,0); }
  // Ab 21 Grad: Rote LED
  { Esplora.writeRGB (153,50,204); }
  // Achsen erkennen
  int xAxis = Esplora.readAccelerometer(X_AXIS);    // X-Achse einlesen
  int yAxis = Esplora.readAccelerometer(Y_AXIS);    // Y-Achse einlesen
  int zAxis = Esplora.readAccelerometer(Z_AXIS);    // Z-Achse einlesen
  //Achsen ausgeben
  Serial.print("x: ");
  Serial.print(xAxis);
  Serial.print("\ty: ");
  Serial.print(yAxis);
  Serial.print("\tz: ");
  Serial.println(zAxis);
  Serial.println("");
Sorry for the german comments. :smiley:
Hope you can help us. :slight_smile:
Your sincerely,
Josh6796
